Anyone do this with a EVGA SuperClocked? 650mhz...
I tried it on my BFG OC but no difference.
\I must be a lucky bast, as my card clocks all the way to 780/1980/2000 (effective), without any BIOS tweaks. Just with a VF1000 fitted. Benches stable too. Im using a BFG 8800GT 512 OC.
I´ll think that BFG OC has higher Vgpu as stock.
It must do. Thing is, i had this card delivered to a mates house while i was working away, and he tested it and couldn't get it above 730 on the core. That was in an identical mobo (P5K-E WiFi AP) and with the stock cooler fitted.
I noticed all the BFG guys are getting to 780 or so....I bet they do have a higher voltage :) .
*smug face!* well, my generous mate, who babysat my card, also bought a BFG 8800 GT 512OC, and his clocks aren't as good as mine, so im wondering if it may be the improved cooling. I rarely see over 50c under load.
My BFG 8800Gt with Stock Bios = around 745Mhz/750mhz
745Mhz@ Stokcooler
http://img100.imageshack.us/img100/181/745de5.jpg
750Mhz@ Stokcooler
http://img89.imageshack.us/img89/5292/750mhzxp4.jpg
I think BFG default bios voltage its same has other cards = 1.1v
http://img405.imageshack.us/img405/9725/11vef1.jpg
http://img405.imageshack.us/img405/1125/nibixe1.jpg
:up:
Does anyone know for sure the 2000MHz rumor about the RAM is confirmed? Is it really bad to run it over 2k? Because with the BIOS from the first post, I can get to 2150 no issue (due to the slack timings apparently).
I assume you are using 3.5a Nibitor? I have XFX and there is exact volts @ 1.05 which I change to 1.1 :)
I also had nothing under the exact volts, but I made it 1.1v and it worked. Max OC increased as expected. I have the eVGA vanilla 8800GT, and it came w/ 600/1500/900 clocks stock.
i used the zotac 8800GT bios, works good, i would suggest that bios, its straight from nvidia, not altered by manufacturer.
link please GAR
:banana::banana::banana::banana: me the RAM gets crazy hot
i put one of my cards on watercoolin for 24/7 rig and damn the sinks on the ram chips are really hot lol
i have a low OCer
tops out at 729/999 on water and it did that on air for benching too :(
but still it's nice
Crysis even with AA enabled and high details is completely playable ,.,,... love it :)
here you go man
http://www.mvktech.net/index.php?opt...filecatid=2259
What advantage does the Zotec BIOS have? I tried the BIOS in the 1st post w/ negligible results. Previously, I couldn't get over 951 on the RAM w/o getting artifacts, and even 951 was giving me problems after some time. I'm at 945 now.
After the BIOS from the 1st post I was testing at 956, but getting artifacts. I might be alright at 954, but it was getting too late last night for me to continue.
Honestly, I think I've got some pretty poor vRAM w/ others getting over 1000 easily.
Same boat here Jason. Mine weren't stable at 959. Clocked back to stock for now. I'm just gonna test my current 740core/1782 shader which seems very stable. Two hours of ati tool without any trail of artifacts and at least 8 hours of crysis without any issues.
