Ccb8f-0720xpmw ....3.5 Air....
Also i removed my IHS on my 5600+ that was running @3.3ghz/lapped same cooler as my 6000+....I dint know the I H S was soldered on at the time. So now i use it to show people what a wafer looks like.R.I.P
This is with a BigTyphoon with a 110cfm fan and Two 2x1gig Patriot 6400ELK@988mhz 5-5-5-12 2.2v on a ASUS M2N32 Wifi DeLuXe and 8800GTS 320mb.
I am getting a ThermalRight 120Extreame to see how much more i can go before i move to water . For now 3.5 on a BigTy lapped Hs/IHS im pretty happy and the 6000+ is only $169.00 NOW!!!! i paid $220 for mine a few weeks ago dangit:am: if i only waited 2more weeks lol.
I have researched this particular stepping and it is the Most recent you can get! CCB8F-0720XPMW .
I checked over 30 chips @Fry's and 24 @Microcenter for stepping numbers that is the most recent i have found from new shipments in Santa Clara ,Sanjose and it is very Oc friendly. My buddy is @3.7 with water on same stepping and he has no chiller! If you keep these things at decent temp they run like crazy.
One last thing these chips like to use TRC of 23 or 24 for high Overclocks and tight timing. The memory controlers tend to do better when TRC is above 21 but not more than 25! I have tested this on my 5600+ and now my 6000+ Also the memory controler also gets real crummy with heat, this holds the chips back the most . So if ya keep it cool these will do 3.6 easy and more with water.
http://i168.photobucket.com/albums/u...3.51ghzair.jpg
