redrol, what settings did you use? I tried getting MBM to work with my DS3 but I had no luck getting it to read properly. Not the voltages or anything. :(Quote:
where can I find a good GPU plug-in for the P5B Deluxe to display NV GPU temp and frequencies??
Hmm, I think I used Asus P4P800 for the few voltages that read correctly and basically just loaded the plugin as per FCG's instructions. Worked perfectly.Quote:
Originally Posted by alejo
thanks for the release :D
but the plugin shows not the right temperatures and not the sensor names here.
all necessary steps are done, i think. or i have make a mistake.
http://pics.mwirths.de/pics/mbm1.jpg
Asus P5W64 Pro
Intel Q6600 ES B3
Windows XP32 SP2 all updates
Don't know if the bug with the CPU-usage is already fixed, but try to disable it in MBM5 and look if the plugin is working now.
Edit: Hmm, normally if the plugin works, the sensors description should change to "CORE X" etc.! Did u started the plugin? :D
http://www.dfi-street.com/forum/show...&postcount=397Quote:
Originally Posted by cdelong
ok. CPU-Usage disable -> still the same...Quote:
Originally Posted by funkflix
ha ha ha :stick: yes the plugin is started. when i stop the plugin the four sensors shows 0.
And the two files are in the correct folders? As is said before, imho the description of the sensors should change auto. to CORE X, if it works.
Let's wait for the autor. :)
Anyone using the Nvidia temp plug-in with a G80 card?
Just wondered if it still worked with the new breed.....:)
Just try it! ;)Quote:
Originally Posted by scaramonga
If it will not work, try the older version of the plugin, because they just read out what Rivatuner reports, so maybe they will work?! But for sure only if u use Rivatuner. ;)
Thanks for the plugin FCG and thanks to all the testers that helped make it possible. :toast:
I see that most have 965/P5B deluxes and have sensible voltage readings, but with my P5WDG2 WS Pro this is what I see for the voltages.
http://i135.photobucket.com/albums/q...FFA22/mbm5.png
Any idea what is going on there? Is it a 975x thing or is it something I've missed or done wrong? It would be nice to get VCore measurements, but not the end of the world if it isn't possible.
Thanks again,
Maff
Hi,
this plugin is only for the coretemp and motherboard indepentend, u must search for special plugin for ur board, to read out the other voltages and temperatures! :)
http://www.xtremesystems.org/forums/...d.php?t=125201
or
http://www.xtremesystems.org/forums/...d.php?t=121183
Nice one fcg, I'll be testing this release later for sure :)
Thankyou Funkflix,
That got me sorted.
:toast:
It's working for me, thanks FCG.:)
Thanks! I used that when I had my DFI, but wasn't sure it would work on the P5B Deluxe for sure.Quote:
Known issues: (only one at this time)
YOU CANNOT monitor CPU Usage using the MBM5 option right now and use the core temperature plugin at the same time. You must disable this option in MBM5 and restart MBM5 in order for core temps to read correctly. I am working on the fix right now.
Sensor names are NOT set automatically anymore. You can set them yourself now. (Users said that they wanted to set them themselved to their liking.) Sensor 9 is 'CORE 0', Sensor 10 is 'CORE 1' and so on...
-FCG
Using it now, thanks! Hopefully you can get the cpu usage going, although it doesn't really matter to me. I'm always at 100% :D
i have disable CPU UsageQuote:
Originally Posted by freecableguy
no problem, but the temperature do not match. any idea?Quote:
-FCG
the link doesnt work.
wats going on ???
Working fine........although a touch erratic compared to 'Core Temp'.......but OK.
GPU temp plug-in working great with G80 also :D
Any ideas as to why the voltage sensors and system temp ain't working on mine? or do they not work on my board with MBM5?
our site hosting is being a little flakey today, we are working on moving over to a new serverQuote:
Originally Posted by tiger64
mbm5 reset vcore on XBX2 = crash
New 1.1 version seems to be working very well Kris, here's a screenshot:
http://img244.imageshack.us/img244/2273/mbmzk7.png
So somehow you made the plugin override the cpu usage thing (disabled in mbm) and handle it itself?
i found the cpu usage bug, and didnt get 1.1 yet :(
well i have another problem, involving 2 windows users, like this
"User A" logged on with mbm running (turned on by start with windows option), when i log on "User B" i get this - see atachment, then the plug in is showing 0c and i cant start or stop it.....this is when mbm starts with windows, although when i try turn it on manualy after in "User B" account it does the same thing
but when both users are already logged on and then I manualy start mbm, its fine on both
both users have same permission level
