think we got some TWINMOS SPEED PREMIUM ...gotta check it...damn 25km driving :D
and cheap too
50$ 256MB
105$ 512
cheap compared ordering etc...
and cheap too
50$ 256MB
105$ 512
really?in that case, i wont owrry too much then....3.3/3.2Vdimm with BH5's shud be good enuff....Quote:
Originally Posted by Revv23
btw, u got any official source where i can refer to bout this? :D
you can probably check the booster compatibility thread, im fairly sure its in there...
http://www.xtremesystems.org/forums/...z+booster+work
Damn Tedy...I feel for you as you have followed this thread the wholeQuote:
Originally Posted by TEDY
entire time and have yet got yourself some dimms to test :stick:
Good Luck
I've tested DC, CPC on, not stable with 225 FSB, in SC with one stickin slot 3 running memtest @ 242 x 11 @3.15 vdimm for one our without errors.
(Bios TicTac D26XT)
http://www.xtremesystems.org/forums/...id=23009&stc=1
Well andy, I apoligise for sounding like an A$$ in that post and im sureQuote:
Originally Posted by zakelwe
your reasons are valid for not Jumping at this stuff...
Cheers to you for your post and speaking your mind... :toast:
And yes you will get your X-Mas card next year ;)
EDIT: Send me a PM and i will ship my 256 stick to you for testing
and you owe me nothing... :toast: Here is what i got from it...
redskin give it 3.3vdimm
you should reach 250-255
I would give 3.3vdimm but it's not possible because there is no vtt mod, I'm going to do this tomorrow. up to now 3.15 is the max vdimm I can give.Quote:
Nice speed :toast:Quote:
Originally Posted by seldomsean
You do not have to send me any sticks as I have some 4 on order, I tend to collect RAM like I do nvidia video cards, thanks for the offer though.
Only 300 1:1 2-5-2-2 will get me excited though, that's like Viagra to us old guys with our X year old sticks of bh-5 :D
Regards
Andy
makes sense yeah....
so dual channel 2*512 not stable even 225mhz only at 3.15 ? that's bad :(
well "burn in" them.....fan blowing etc......GL
yo dc not stable at 225, but not munch tested so far, only single channel 242 @ 3.15vdimm with one stick, gonna test the other stick in single channel too.Quote:
nforce2 with 2x512 really sucks for me
did burn in already (9 Hours) :D
only comforts me it's you got sucky mobo and me some ownage NF2 one :=)
j/k ::D
Thanks Bro...Quote:
I see you have been bitten by the "Bug" Also :cool:
Look forward to seeing your result's(Kinda like Gambleing) :banana:
I do know that if "twinMOS" does what there sayin here then this ram
should be "Flooding"the market so to speak so there isnt any rush to
go and order this stuff...Actually it might payoff to wait and see what
happens...
Cheers,
-Sean
Newegg has the 512 SP back in stock! ----> link
7pm est they only have 2 left in stock. If you want them, NOW is the time.
My 256 isn't doing so hot, with 3.3vdimm I can only manage 245mhz 2-2-2-5 1T 3.3v memtest stable. However I can bench at 250mhz stable :confused: but it don't pass memtest or super pi.
Originally Posted by WesM63
Are you able to give it 3.4-3.6v ? That seems to be the sweet spot for these sticks.
Originally Posted by scifikg
LMAO.....7:10pm EST and the last 2 sticks are gone. :eek: :D :p:
Originally Posted by sparkie34
Sure can, well I think anywase, I don't know if this board has any OVP or not. I'll try running 3.6v through it and see what happens.
DAMNIT, missed the sticks, got an instock email at 3:37 this afternoon... got home from work at 8:20, and they're gone.. :(
EDIT: haha! things went back in stock at around 9:10, and i got me 2 from newegg! :D
i just did FedEx express saver, 3-4 bussiness days, but newegg doesnt process on weekends, and they need 24-48 hours processing time, so that sounds like next thurday. tis ok, i dont have the rest of the system anyways. :D
well sad to say, I tried max of 3.2vdimm and it didnt get me anywhere with 2*512. I think the AI7 undervolts. freaking thing wouldnt even post if I try even 220 2228 timings. I guess volt modding is really needed for this one.
Well, you are not alone in your woes. I'm in the process of doing a burn in because I wasn't having a ton of luck right out of the box. No DC at 200 with 2-2-2-5 for me, even at 3.2v! (Correction, that should read at 3.3v, not 3.2v).Quote:
Originally Posted by situman
I do have another factor at work for me here besides the ram and that is that this is a new build I'm using to test. The OCZ PC2700 sticks wouldn't boot in DC either, and I'm getting Memtest errors with some TCCD, as well. While these Speed Premiums are doing a burn-in, I'm putting together another rig to help determine if it is the sticks or the rig.
On a side note...so far it appears that those back in stock emails go out just after 6:00 pm EST, so if you are in the market for TMSP, keep checking the stock beggining sometime after 5:00 pm. And keep checking!
I am basing that last comment on observing date/time stamp on the "back in stock" posts made here, as well as over at OCF. May or may not be true, but appears to be the pattern.
some guys @ hardwareluxx.com said , that the UTT's doesnt perform well @ s478 ...
Hipro5 posted decent results on an Intel back on page #5 and another guy, Diablo23RD over at OCF has hit 250 plus with his on an IC7-G/3.2 rig, but yes, most of the better results have been a64 rigs.Quote:
Originally Posted by $ilver
The OCZ VX also works better on A64 so there may be something to that. It is very possible that those same sticks that Diablo hit 250 plus on would do 270 plus on A64 and I do believe that hipro's sticks did better on A64 as well.
i also had no luck running 2x512MB TwinMOS Speed Premium 250 2-2-2-5 @ 3,3 on a P4C800-E PAT enabled while they did 260 2-2-2-5 1T on K8N Neo2 also @ 3,3
