LOL, why? Do you know the reason? :D
No, it didn't misread my 975 because i have 920. Probably some bug... But still, it's a WR with i7 920. rofl :D
Not sure, shut it down one night and the next day the board turned on but no Debug LED. Tried all the troubleshooting that Saaya listed and then some. Now I am just waiting on Foxconn.
Huh WR? :p:
http://valid.canardpc.com/cache/banner/636721.png
Now you can pull that trigger punk :rofl:.
Well, your cpu is a W3520 and he's got a 920 ... :D
Hi any one has any info on this BATCH # 3851A257 :rolleyes:
Still hunting imo ? :D
Think I saw some W3540's with that batch, did ok - but not as good as an avarage 45-49 if i recall correctly.
Not really as I was offered one of those in weeks time what can I say the price was $400 attractive for w3540 isnt it though im not sure whether i will be able to run it with the P6T Deluxe which has the anti-throttle 007 bios now :D
3845B260- same one as Eva2000:D
Rest of specs in sig
24/7 use
[IMG]http://img402.imageshack.us/img402/1...lex15biosf.jpg[/IMG]
Not 24/7 use ;)
[IMG]http://img263.imageshack.us/img263/8...7ghzspi32m.jpg[/IMG]
Hi guys
Can you help me?
I have an Oc stable, 4.0 no Ht with Rampage II Extreme, but i need to use a lot of vcore to get it, 1,318, and i have a D0
I just tried everything, increase cpu pll, , qpi/dram...... but no sucess, i only can be stable with this vcore and without ht, if someone could help me i`ll be very happy:
System specs and bios specs:
Core: i7 920 D0 Batch: 3851A231
Psu: Corsair 1000 Watts
Memory: Corsais Xms3 1600 XMP 9 9 9 24
2x Radeon 5870 Crossfire
Cooler Noctua nh u 12p SE
Now the bios
version 1504 (latest)
Xmp mode Oc
200x20 = 4.0
Vcore 1,318
qpi/dram 1,35
pll - auto
dram voltage 1,65
uclk 3200
Loadline - enabled
c1e - tm - speedstep - disabled
ht - off
ioh - ich - Auto
Thanks again
wsarahan - You are using the 20x multi which requires more vcore than the 21x multi. It's not likely you'll get the vcore significantly lower than it is now using the 21x multi but it should lower it a little. You could also use the 19x multi.
Is it really necessary to lower the vcore just for the sake of it though? If you want 20 x 200 and it takes ~1.3v then that's just what your cpu needs.
This really is just a batch/results thread though, for basic overclocking advice please refer to the appropriate motherboard thread or make another thread in the appropriate section.
Nice, that is a very cool CPU.
4.2GHz low Vcore
It comes to work with low Vcore when the temperature falls.
To prove the process, a big image is put
http://happy.ap.teacup.com/yomoyama/img/1257313338.jpg
http://happy.ap.teacup.com/yomoyama/img/1257313363.jpg
CPU:Core i7 920 Lot.3845B027
cooling : SCMG-2000 Room temperature 14
CPU Voltage: 1.18750V
QPI/DRAM Voltage: 1.30V
CPU PLL: 1.80V
IOH Voltage: 1.10V
IOH PCIE Voltage : 1.50V
ICH Voltage: 1.10V
ICH PCIE Voltage : 1.50V
DRAM Voltage: 1.64V
Load-Line Calibration Enable
CPU Clock Skew : Auto
IOH Clock Skew : Auto
HyperThreating: Enable
PCI-E 103MHz
Update with a 4096MB linx run
Load
http://i720.photobucket.com/albums/w...1112v128-2.jpg
Idle
http://i720.photobucket.com/albums/w...1112v128-3.jpg
Aren't you guys afraid to run your PCs 24/7 with anything above 100Mhz PCI-Express frequency?
Didn't we have numerous reports that it kills HDDs, NICs and video cards long term (short term for high frequencies)?
Is that directed at me or momoto? He's only at 103 MHz, that's hardly a concern imo. On X48 I've run PCI-E upwards of 120MHz wih a SATA HDD and GTX285 for more than 'short term'
with no ill effects or issues whatsoever. For my clocks above on X58 raising PCI-E over 100 MHz is not necessary.
I see some low-volt action is going on, which reminds me of my good old high- BCLK & low-volt summer 24/7 OC.
W3520 @4.01GHZ(19x211) 1.15v, 8 hours Prime-Blend, stable
http://img7.imageshack.us/img7/6503/...d8hour2.th.jpg
Same setup has passed 11 hours small fft too, and later was stable with x8 RAM, and even 12GB RAM and x18 uncore. It has been running so cool :cool: that I sometimes really miss it.
Nice clock & CPU Sam.
Thx, :) yeah I'm happy with this one.
You got a good one yourself. :yepp:
Thanks, yeah I'm happy with mine too. What are your temps like on air at 4.41?
beat my old score at almost 50Mhz less. Hmmm, wonder why. Anyhow this is my daily rig I'm scared to push more.
Batch # 3849A866
http://img.techpowerup.org/091105/Capture175.jpg
Nice clocks Chicken Patty. What volts do you need for 4.2 with ht on?
I7 950 Batch: 3910A470
Primerun (it's an older one, did some Cooling Rework, have to re-run)
http://www.abload.de/thumb/p95_small_ffte93x.png
Some other shot's:
Everest Cachemem
http://www.abload.de/thumb/8-8-8_22_1t_settings8kly.png
Cinebench
http://www.abload.de/thumb/cb10eyrb.png
PI 1M @4,8
http://www.abload.de/thumb/pi_1m_08.522l62x.png
PI32M @4,7x
http://www.abload.de/browseGallery.p....20090d413.png
have to do some tweaks that i can prime @4,8 :)
