Just have those 1600mhz dominators CL8 here.
Just have to browse my bios now to see what things all you have mentioned. :D
I just have played around with QPI (do you call it vtt?) Vcore, VDIMM.
The things you mentioned I didnīt touch yet *grin*
Is it not dangerous to have such a high VTT? (24/7)
Intel Spec max is 1,35V
nope been running 1.48-152v for nearly 2 months 24/7 no issue with atleast stress testing for a few days non stop.
I raised IOH and ICH to 1,28V and tried 211 BCLK. It seems to work now with qpi 1,34
This is already a little step of succes to me. :) Thought I might look for my 24/7 Settings a little bit above 4 GHz.
I can easy go to 4GHz but after that it sucks....I have missed some settings. How much do you guys raise your QPI/DRAM, IOH and ICH? What about: CPU differential amplitude??
ATM i run 133x30, Vcore 1.32 (cpuz) QPI 1.3V IOH and ICH 1.12 (stock). That is stable.
My nb run rather hot, nearly 50 degrees during load. It that a problem?
I try to find a nice 24/7 clock around 4.2GHz but right now Iám stuck!!
I have much to find out with this board! :)
Could anyone tell me the max safe/stable temp for running the Intel Burn Test on a 920 with Rampage II Extreme? I know IBT really burns it even over Prime or SuperPI, so I don't want to be in danger of hurting my CPU. I hypothesize that it could be over 70 or 80! Thanks
cstkl1, Finally reached a 221bclk. Wouldn't boot any higher than that.
http://valid.canardpc.com/show_oc.php?id=518145
Looking at this guys results:
http://www.xtremesystems.org/forums/...d.php?t=219476
on a gigabyte extreme, he says he can't boot beyond 222bclk and had to set it higher in setfsb. So maybe that's what we need to start doing for beyond 221bclk. I'm guessing there is a 4ghz qpi limit as around 221-222bclk you are reaching the 4ghz qpi wall that everyone talks about. Maybe asus can address this in the next bios or tell us how to get around it. I haven't seen the dfi or evga having problems booting past that bclk, so maybe it's a bios fix.
Posershadow, what voltages did you need for that? nice clocks:up:
Yeah i've read the manual and applied the method but when i press "CTRL + I", all the disks are under status "non RAID Disk"...
So i think the reason is that when first, i installed my OS, after doing the "makedisk" from my Rampage CD, i've used the F6 method with only the "Driver AHCI JMicron JMB36X 32bit".
May be i should have to use a second disk whith F6 method with the "Driver AHCI/RAID Intel ICH10R 32 bits"...
that's right ? Can u confirm that ?
There's something not quite working properly with the Intelburn test. On the i7 with HT enabled the cpu hover around 50% without fully maxing out any core for the duration of the test. Try LinX instead http://www.xtremesystems.org/forums/...d.php?t=201670
thats one of the reason trying with the dfi..
trying with lower ram mhz and with the gt so no limitation by the ram this time.
the dfi doesnt seem to be so fussy with the ioh/ich ..
is it a design problem?? on the digital vrm vs analogue phase??
still want somebody to give a genius answer as to y asus thought running the qpi/dram card seprately was a smart thing to do
doesnt this create a lot of flux,
Damn it! My RAM wonīt boot at 1690 :( Had already 1,67V But it wonīt boot. 3x2GB Corsair 1600 8-8-8-24.
Would fixing the latency help me out?
Setup my new system over the weekend....REII / 920 / Corsair PC3-1600C8.
Flashed to latest bios and straight in at 4.0 @ 200 bclk with HT/Turbo both enabled, linx stable.
No cold boot issues either, using an Enermax Infinity 720w.
Can anyone post a pic for a gettomod for nb? :)
My running rather hot so I have to do something. The problem is the space....almost nothing when I use my TRUE-black.
Itīs tricky to even put a fan there!!
hi...
i've set my dram frequency to 1600mhz, timings to 8-8-8-24...
when i typed 1.65 in the dram bus voltage, it changed it to 1.65680
is it ok to run it at that voltage?
been monitoring it... the dram bus voltage sometimes goes up to 1.66...
should i set the voltage lower?
