Im at 5ghz with 1902
andressergio
you will show your BIOS to 108 blck ?foto
sure mate
http://img196.imageshack.us/img196/3175/5600108x52.jpg
Uploaded with ImageShack.us
hmm not this foto,from bios ;)
Still running my system at 1.375v 5ghz
have a problem with the latest bioses my setting in aida mem bench dont show up right!
http://i19.photobucket.com/albums/b1.../5Ghz1375v.png
damn sorry Martin lol i will take and post now
http://img88.imageshack.us/img88/8120/110916230806.jpg
http://img825.imageshack.us/img825/6...0916230831.jpg
http://img840.imageshack.us/img840/9...0916230903.jpg
hope are useful for ya
cheers
Serg
ty
is it whit c stat ? on
ty
max blck whit this cpu on water is 106 x 50
but whit DICE I can 101 x56
vcore hungry cpu :(
Sorry a bit OOT:)
I just got its brother Asus CH5 Formula (preping for AMD FX cpu) and really like it....Easy 2100 7-6-7-20 which is the first time for me. Lol
what was that "skew driving voltage" for?
sorry i dont know :(
like an offset?
M4E will support the new Intel 22nm cpus ?
thanks andre.. i'm trying for 108 myself.. on my ud7 i ran 106.5blck 24/7... you think 108 24/7 is possible without running into any issues?
EDIT: most i can get on this is 105.5 with skew driving voltage @ standard 1.04 and blck skew @ -10 :(
bios 1850
cheers
my UD7 B2 does 107x but never tried for 24/7
keep trying on the mive
here's some nice guide for ya
http://kingpincooling.com/forum/showthread.php?t=1041
cheers and good luck
Serg
thanks! as i read the guide... i knew what i did wrong, i was just plugging in settings without slowly easing into it. So i did what i had to do with my ud7... went up in blck by .2 each time, reboot do the same thing until i got to 106.5. Old ud7 would revert back to old bios settings from cold boot though... hopefully this doesn't.
Used skew driving voltage: 993
blck skew: -12
Will keep trying to push it.
Appreciate your help andre :)
http://img405.imageshack.us/img405/296/blckmive.png
@ badatgames
here is an older screen shot of 107.6 with voltages that might help you, it is not really efficient as I was just trying to see if the mems would run 2000 6-8-6.
http://i.imgur.com/bPZqk.png
that was on water and with no tweaking of any of the bclk skews / driving voltages, so I imagine 108ish is doable with some work, at least on that chip.
Guys I just got my hands on this board and a 2600K . I have a couple of questions which bios is best for the highest 24/7 stable overclock? also I have noticed two four pin molex headers on the board but on the Quick Start it does not tell you to attach anything to these headers?? Are you guys attaching 4 pin molex connectors to them or not?? and what are they for ? Do they improve stability etc??? Thanks for your help.
