At this point I want to see what happens to mine, so I'm running it, safely.
It will be interesting to see what happens with the replacements.
At least I'll have a way to test that too:)
I.m still waiting for a response from brian
Got the email from Brian too.
Hopefully these will be the final fix and all will be well.
Fingers crossed.
received. (Free stuff + the correct version of T3 + _no leaks_) == bought.
Meanmoe can you see any changes from the old T3 or does it look the same?
the people who start getting them first need to post pics and be test guinea pigs for a bit :D haha
hope the new T3 has a thicker wall
I think all the T3 needs is a thicker wall but does that not require a new mold?
I got my email to and it's dut to be sent today or tomorrow.
I hope this T3 is the one.
i hope so too, i really want to get one but not be paranoid, or i might just make an aluminium tray with sides to go into the bay below it to catch any potential leaks hmmm
I heard there is a new SpongeBob Square Pants edition
Well, Rev A. is in stock and being sold. I couldnt stop myself and ordered one. I'm not sure what sort of emote I should even use for that. Feel free to make fun of me, if it starts doing its leak thing. :doh:
i really hope for everyone who got a dodgy one and for primochills sake that these ones are going to finally be good, wish he would comment on here about what's changed and what testing they've done
I would like to think the screw holes have all been strengthened in some way.
That was always it's achilles heel to me.
It's the only part that ever failed.
How they will do that without making another mold is beyond me.
someone has a picture?
I got my replacement in. I'll get some comments up shortly.
Dreddy did you get Brians email about installing the backplate?
He says to tighten each screw at 25% until all are tightened.
He also says to pinch the backplate onto the T3 while you tighten it.
I look forward to your review, don't take to long.
Does it look any STRONGER? or Thicker just from looking at it?
I really want to replace mine even if it is not leaking, I have to much money in this system to fry it with a Bunk Res.
Alright so here it is. The first thing I noticed, was that the glue job, is a bit sloppy and rushed by comparison
http://dreddy71.webs.com/T3/Sloppyglue.JPG
Also, the mold mark on the right side is still there, but is less noticeable.
http://dreddy71.webs.com/T3/Moldmar.JPG
So what did they fix? From the looks of it, I believe they thickened the outer walls of the back, but not the back itself btw
http://dreddy71.webs.com/T3/Wall%20thickness.JPG
Also the screw holes were culprit #1. They’re trying to remedy this with smaller screws and gluing the "nut" into the original holes. Let’s hope they used a semi flexible glue lol.
http://dreddy71.webs.com/T3/Screwhole.JPG
By the way, the new screws are tiny!
http://dreddy71.webs.com/T3/Screws%20&%20orings.JPG
Also, they didn’t seem to package the "washers" for the fittings, and included bigger o-rings for using other fittings instead. That impressed me a bit.
http://dreddy71.webs.com/T3/Free%20Bling.JPG
And who can say no to free bling? Well, not really free, I did have to sit around without a T3 for a while.
Darn image hosting failures making me use my backup hosting...
lol . . .
