Your idle temps don't seem that bad. I'm running at the stock voltage/frequency and my cores at idle (with no calibration) are at 38/34/40/40 but the last 2 don't ever register below 40 so ignore them.
CoreTemp has a Vista sidebar gadget out now, you must be making them sweat unclewebb. If and when RealTemp has one available I'll ditch CoreTemp. Thanks for all your hard work.
http://www.overclock.net/software-ne...p-add-ons.html
http://i239.photobucket.com/albums/f.../MyDesktop.jpg
How do you calibrate real temp? I see it in setting but, how do you go about setting it?
This is a good place to start: http://www.techpowerup.com/realtemp/docs.php
Apology accepted Nano74.
You're upset with the TjMax that RealTemp uses for your CPU so can you explain to me what TjMax you have chosen to use and what that's based on? Do you have any new documentation from Intel that I don't know about or any testing that you've done or is it based on some other programs that have chosen to use a different TjMax than what RealTemp uses? The competition hasn't posted any real world testing that I'm aware of.
I think RealTemp, CoreTemp and Everest all let you select whatever TjMax you want these days so you can pick whatever program you like and adjust it accordingly.
If you're interested in some of the testing I've done then read through this 50+ page novel. This thread is an excellent source of temperature information from all users.
kpo6969: No need to ditch CoreTemp. As long as you've set it to use the correct TjMax, which you have, then it's full load accuracy should be the same as RealTemp. Idle temps might be out a couple of degrees but they're not that important anyhow.
I haven't jumped on the Vista bandwagon quite yet so a sidebar for RealTemp is still a little ways off in the future. This may be sour grapes but I find CoreTemp and Everest both have too much information in their sidebars which makes it hard to see. I prefer the size of font that the weather gadget uses so it's easy to see your core temps at a glance.
alex17 GTX: RealTemp has been using the same VID formula since it introduced this feature. I read in the E8400 thread earlier today that you can do a Register Dump in CPU-Z and it will show you the max VID in the file it creates near the top. So far I haven't seen any difference between what it reports and what RealTemp reports.
I was playing around with a slightly different user interface this evening.
Someone once asked if I could make the temps stand out a little better.
The important numbers are pretty easy to read from a distance with this version.
http://img147.imageshack.us/img147/2966/rt262cs6.png
If you want to take it out for a run then download it here and place the .exe in your RealTemp directory as usual.
http://www.fileden.com/files/2008/3/...alTempBeta.zip
Any feedback is always appreciated. After staring at the old version for the last few months I thought it was time for a change.
EXELLENT !! unclewebb thats helps all us 1 eyed clockers hahahahaaa
finally can use your program whith my new E8400 hot rod ;)
Here are the settings that I used...
Attachment 80457
And here's RealTemp v2.62 Minimized...
Attachment 80458
And here's what I previously had with RealTemp v2.60 Minimized...
Attachment 80459
Did you intentionally leave out the degree symbols and Cs? So far that's all I see.
By the way I do wear glasses and who knows when I will need this option.:D
thanks uncle...at least i don't have to use my glasses that often :D
msgclb: Thanks for noticing the missing symbols in the TaskBar. To center the temperature numbers in the dialog I had to remove the degree C sign but I guess they accidentally got deleted from the TaskBar as well. I'll fix that back up.
When you're running Prime it's nice when you can see the temps from a distance. My next plan is to be able to Minimize this dialog so only the top third of it shows similar to my MHz utility so it doesn't take up too much space on the Desktop.
Thanks HDCHOPPER. Whenever I'm checking out the E8400 thread it's always nice to see that famous quote.
Edit: I found the missing degree C symbols and put them back where they belong in the TaskBar and System Tray areas.
@uncle: would it be possible to put the min/max temps in a tabbed version? maybe as well as the settings? basically just like how cpu-z shows & could just shift from cpu to motherboard to memory via tabs. at least that would save some desktop space. just a suggestion tho :D
emoners: CPU-Z like tabs is a good idea. I've never used them before so I'd have to open up my C++ book, again!
One of the reasons why I like the Settings as a separate Window is so you can make adjustments to TjMax or the Calibration settings and see exactly what effect that has on your reported temps. At the moment, I'm just going to go for a quick and easy mini option for RealTemp so you can see the important stuff without it overtaking your Desktop.
http://img71.imageshack.us/img71/4161/xpsidebartq3.png
Thxs Uncle to recive my apologyes!
I was lookin for Intels documentation and i didnt find anything about 45nm TJmax.
So i was following this thread and i sow many people here posting his Temps with their proccesors with real temps and i noticed that real temp shows lower temps than everest and core temps if u dont change tjmax, for example, everest read to me 105c with out manage tjmax manualy, and core temp same thing, but with reral read me 95c in tjmax wich its reead 10c less in all cores, for example:
Everest and Core temp: 49-39-49-49, after this i ve tested with real temp 2,63 and my temps are 39-39-32-40 and prime stable about 2 hours in real temp 45-46-38-47. so is good news in real temps because with this test temps re so lower and nice.
So, pls Uncle u know there is 5 diferents temps , one for CPU ad 4 mmore for each core (in ma case that i ve a Quad), and the cpu temp is 34c, whic for me in prime stable increase to 42c, and is hi comparing with 65nm or another 45nm that i sow in this thread. Not all is only core temps dont forget is CPU temps too, pls explain me if i m wrong bout avg cpu temps is 60c when i OC my q9450 to 3,7ghz with a zalman 9700 and mx-2 termic paste.
tnxs for your knowledges!
See u:)
Do you want to turn your processor into one of those super chips that has a nice low VID?
http://img177.imageshack.us/img177/4905/lowvidve5.png
One quick change and my Q6600 drops VID from 1.325 to 1.1625. Perfect for a screen shot or when heading to EBay. Buyers will pay extra for a low VID chip. :D
CoreTemp, CPU-Z, Everest & RealTemp all report this lower number which means that VID probably changes depending on your motherboard as well as how it is set up. C1E did not need to be enabled in the bios on my board for this to work so give it a try and see if you can create a low VID chip for yourself. Maybe users will start comparing Min and Max VID now.
My daughter told me I was getting a little carried away with the "eye chart" temp numbers so I've used a little restraint with the latest version.
http://img293.imageshack.us/img293/9484/rt264ey6.png
Once I get the mini mode working I'll post an update.
In CPU-Z if you go to the About tab and click on the Registers Dump button it will at least give you your Maximum VID value for whatever that's worth. It reports 1.325 for my Q6600.
I think too many users have been comparing Maximum and Minimum values from different software and different versions of the same software while running on different motherboards. I hope more users post some data so we can see if there's a pattern here. At the moment, most of the VID data that's been posted in forums is useless.
Had to disable OC, back to auto get VID change to work, but that was interesting. Top pic is with laptop power scheme showing VID 1.15, bottom pic is desktop power scheme which shows my max VID of 1.225
In this Core Temp 0.99 I found the Register Dump in the Options menu. I can't find any VID in the dump. After the top data as shown below, it is all hex. I haven't tried your power option yet.
Attachment 80553
msgclb: The Registers Dump in CPU-Z shows VID. I don't trust CoreTemp since version 0.99 is still getting my T7200 wrong compared to what CPU-Z says.
I noticed a coincidence while doing some testing.
http://img207.imageshack.us/img207/7...irfightmh7.png
Which one of these utilities gives you more useful info per square inch? The recent RealTemp diet has got these two ready to go head to head. I turned off RealTemp's calibration features and set TjMax=100C so at least it would be a fair fight! :D
