Can you please check this screen, mem can handle 800 Mhz at a low voltage.Quote:
Originally Posted by HamidFULL
So I dont think its the memory.
http://img441.imageshack.us/my.php?i...mhz195viz3.jpg
he already stated that the ram does 400+ on another board.
but i questioned the ram long ago when he first made a thread about the system.
wth is MDT ram anyways.. who makes it ?
and just cuz the ram claims to be this or that dont mean much. even the OCZ XTC 667 ram can BARELY run 800mhz so that doesnt necessarily mean you can do really high with yours.
and ram will always act differently from board to board. frankly i still say its your ram. and there is only one way to know for sure. try other ram.
http://www.mdt.de/eng/about_start.htmQuote:
This is not on another board, its on the DQ6 :) .
Next big chanllange is to do a fresh install of Windows XP and see if the Plextor drive will install Windows without error + the RAID array setup.
Bios looks pretty much the same same before, save for the system voltage options being revised, the colors on grey/pink/flashing red are back once again under VDIMM....a new green colored string has been added.
http://img507.imageshack.us/img507/6...z21vdq6ww5.jpg
Even stable at 429 Mhz, so I say my Motherboard sucks :) .
my result on F6b 3465MHz on 1.37500v look :
http://www.xtremesystems.org/forums/...61#post1759961
Nice, but you got a C2 revision.Quote:
435 and still going.. so its not my mem/cpu what is it??
http://img182.imageshack.us/img182/9511/43521vze9.jpg
AgreeQuote:
did you know some memory cant support 1:1 FSB? like my old Crucial Ballistix PC3200 that could run 280MHz on divider and only could run 254MHz on 1:1Quote:
Emperium
but mabye bad DQ6 or E6300 and best way to solve your problem is test another hardware
i was just gunna say the same thing. it may not like 1:1 ratios.
usually though the chipset is the failure when a 1:1 ratio doesnt work. the chipset is flawed and cant handle the stress.
so go buy another board and stop wating your time man....
infact RMA the board. since you can prove the ram will handle 400+ and yet the FSB wont i would suggest calling gigabyte and explaining to them the issue... if they deny you tell them to bend over and let you screw them as hard as you just got screwed. if they do the rma then thank them kindly and send the board back to them.
Emperium,
Why are you so certain that it isn't the limit of your CPU? And just one other question no one hase come with yet, could it be your power supply?
Groeten uit Alkmaar Dutchie :p:
Means NOTHING!...run 30 hours of Orthos dual prime stable and then get back to us.
Right, did a fresh install of Windows XP Pro SP2...went fine, zero errors, Plextor is detected in bios and can be set as first boot device etc.
In Device Manager the Plextor just gets listed under CD/DVD-ROM Drives...
I am gonna try one more thing in regards overclocking the CPU, i'm changing my graphics card to a Gigabyte 7600GS.
Maybe it's that, if not then screw it...i'll splash out on a quad core.
Originally Posted by TheForce81
Because it worked fine @409 FSB on my old DS4 at 1.4v I am sure its not the CPU :) . And I know 100% sure that he can take more then that.
Groetjes terug uit Breda :D .
I have mine at 420FSB with no MCH or FSB voltage mods:
Gigabyte - DAMN YOU!...da hell didn't you fix the SYS_FAN bug you muppets!
How long do i have to tolerate this tornado going on in my case!!
Hmm, how much voltage do i need for this?, because Orthos fails with bios set to 1.4250V (1.4000V with VDroop)... :slapass:
Originally Posted by Richard Dower
Can't you resize that picture? I say give it until he is stable:banana: .
Awww crapola, no new DS3 BIOS??? I had my hopes up!!!!
Me -> :stick: <-DS3 BIOS Team.
Yeah, but it's at 7x multiplier on your E6600, which is useless.Quote:
Have you even properly tested that CPU with 3.7GHz?...have you ran 30+ hours of Orthos while running several other stress test programs at once?
And you're using water cooling + probably a crapload of voltage which will reduce the life of the CPU.
Yep it's Orthos stable :) .
I can play games 24/7 at 3.8, but it's only 100% benchable at 3.7, hence the 3.7 in my sig. It's only at 1.525vcore with the F5d BIOS. But I could hit stable 3.4 with NO voltage adjustments to the CPU, Mobo or RAM in BIOS with stock cooling.
See http://forums.overclockers.com.au/sh...13&postcount=4
You're whining about your system fan, and SATA optical drives etc, but you're running your E6600 at 7x. As I've said above, if you were serious, you'd pull your system apart and test each component to see where the fault lies.
What the hell?
My temps dropped with 10c in TAT, with F6B
Core 2 with 4MB cache have lower OC ability than 2MB but one time increase your Vcore to 1.4550v and test it and one time decrease your Vcore to 1.3850v and test it sometime higher vcore cuase lower stabilityQuote:
Richard Dower
Great! I'll test it but you test with coretemp and everest?Quote:
Originally Posted by DesertShooter
my coretemp dont show lower
isn't that a good news? or bad?Quote:
