yah 5-6-6-18 @ 1066
yah 5-6-6-18 @ 1066
toss them in the freezer
not D9's, they were just some cherry gold's that could do 5-5-5-15 until saturday....figured I'd let them go out with a bang.
put them in the freezer anyway it fixed my promos
nah screw it I'm having fun till they die completely 1265 now mwahaha :ROTF:
just dont kill the phenom like i did lol phenom2+3.5v=dead phenom
How many volts you running at that RAM speed?
just bumped it to 2.25, had 4 errors in memtest at 2.2v
I lied massman, I could squeeze more out of them, massman let me know what the efficiency comes out to, thx, can we figure in the cost of the ram :p:
http://members.cox.net/bostonreefer3/massmanPI3.JPG
http://members.cox.net/bostonreefer3/massman4.JPG
This UT 790FX is the last DFI board Ill be using with the PhII.
I ain't going to bother with them anymore. Once they were the overclocking name, nowadays about any board can OC.
The water is epic:up: Quad rad and all, 36C at 3.7Ghz/1.55V and 2Ghz NB/1.25V:cool: Think I could have done better with installing but it works, pretty good as well.
I think I have the lead on air now. :cool:
4408.38MHz(only 0.16MHz ahead of Lightman); 1.536V, and the "golden" IFX-14 with two akasa fans@2300RPM. :)
http://valid.canardpc.com/show_oc.php?id=514871
The next victim is BenBrown. :D
WTF dude, nice work!
Do you have the IFX-10 installed as well? That thing killed my board, I took it from 15~20C to ~5C but those little heat pads on the back of the motherboard somehow started to lose some sort of oil:confused:
Quite pissed about that, but the IFX-14 back plate is usefull for my EK Supreme block:p:
Thanks for the congrats. :) Same sh*t with IFX-10 on my board. It was installed 15 minutes or something like that and after minor mod on my original backplate that comes with the mobo I threw away the IFX-10 away. I'm pretty sure that IFX-10 was designed for intel mobos and was not fully tested on amd. A lot of friends was trying to convince me that I'll have no problems with the stock mounting kit of the IFX, but I preferred to bet on safety.
Well I figure it's time to get my rig up on the list eventhough I am not yet happy with the OC - I think I can do better !
Not Prime / OCCT stable.
Phenom II X4 940 Black
0850CPBW 80243
3718mhz
1.44v
NB = 2200
HT = 2000
1066mhz DDR2-8500
Memory Configuration 2x2gb
Memory Unganged
DFI LP DK 790FXB-M2RS 1/20/09
Watercooled
Windows 7 x64 beta
http://valid.canardpc.com/show_oc.php?id=512930
Try overclocking by bus, not by multiplier. You may achieve better results. Also try with 1.46V+, 1.44 can be not enough for this cpu and 3.8GHz.
Ugh, my board/CPU is epic weird:confused:
Im almost convinced it doesnt like Vdimm, whether it's the CPU or the board, I dont know.
However, running 2.2Ghz NB and 3.7Ghz CPU stable now. PWM's are squeaking as usual:shakes: Funny thing is it looks like temps dropped slightly with higher NB clocks/Volts:confused:
@Ramm - did you increase the CPU-NB voltages (from 1E default) ?
Stable 4h, quit it.
Doing now 3.8Ghz attempt again, I set Vcore up two notches (1.5625, although OCCT reads 1.55 still).
My PSU seems to have a slight ripple on 3.3V, it jumps up and down between 3.28 and 3.3V, OCCT says a 0.49% ripple. Ive seen PSU's suuplying worse than 3.28V, without ripple. Guess it ain't much of a problem:rolleyes:
EDIT Oh lol, 3.8Ghz wasnt stable, G15/G5 lost power and screen went black. Checking whether this is due to a multiplier limitation from the MB or just a wall for this Voltage in general. Instead of 19*200 Im doing 18.5x206. It's kind of weird to test with a possible broken motherboard but well
@Ramm - nice try. Have you tried a newer Beta BIOS ?
Should be able to crack it ;) i was on a cheap cooler when I did it.
http://www.xtremesystems.org/forums/...d.php?t=218111
