I added support for Core i3/i5 ClarckDale CPUs in this version: CPU-Tweaker 1.4 beta6.zip
Specials thanks at Kyosen and Mad222 for theirs tests.
As always, let me know if you find bugs or problem... :)
Hi, I have some issue here with CPU-Tweaker, I tried version 1.3 and 1.4b6.
Using a Athlon II X2 250 + ASRock MoBo with GeForce 8200 Chipset.
CPU-Tweaker won't read SPD Timings, it shows "empty" for all DIMM slots
and I cannot select Channel A & B (A B) it just jumps to A instead.
Another thing is that i cannot change the UnCore Clock
but this might be a Chipset limitation (?).
PS: CPU-Z register dump is prepared.
CPU-Tweaker don't read spd timings on nvidia chipsets. (I don't get any datasheet for it)
For Channel A, perhaps your cpu run in ganged mode.
It's unganged actually.
...could you make a registers dump and send it at memset@hotmail.fr
Thank.
...fixed in this version: MemSet 4.1
Hi all
I have a problem with CPU Tweaker, I canīt apply changes because I donīt have a "APPLY" button, it says "MC_CFG_space Locked.", see screenie below.
http://i282.photobucket.com/albums/k...CPUTweaker.jpg
Why is that, is it my motherboard that donīt admit it?
I run a Rampage II Extreme, bios 1504, i7 975 and using XP Home SP2 and doing some benching.
EDIT: Itīs the same with 1.4b6
Thanks in advance
Ghostleader
...the PCI configuration space is locked by the bios, I can't do nothing.
thanks Felix, great for clarkdales too!
...the best way is that your motherboard manufacturer accept to unlock it in the bios!
For more information, read post #1184 in this thread.
New beta version: CPU-Tweaker 1.4 b8.zip
-Interface was changed for Intel CPU (Core multiplier control is on the main window now)
-Add the change of core multiplier for Intel Core i3/i5 Clarckdale CPU.
-Improve the change of core multiplier for Intel Core i5/i7 Lynnfield CPU.
Hi Felix,
thanks for update.
Why in beta 8 CPU is greyed,but in beta 6 it's OK?
http://i10.aijaa.com/b/00659/5676558.png
...simply cause "CPU" window is obsolčte for Core i3/i5/i7.
All features you found in this windows (EIST, C1E, Turbo and Multipliers controls) are now in the main window.
Edit: if you have 2 minutes, could you check that turbo multipliers work with your CPU... thank. :)
Yes,it's works!:yepp:
Thanks for explanation.:up:
thanks Felix.. would it be possible to add spd one line under board model/bios for the memory module's manufacturer + number ?
i.e. A-DATA Technology DDR3 2000X
http://fileshosts.com/intel/DFI/dkp5...m_10s328ms.png
...of course it's possible, and no complicate to do.
It could be a good idea...I see what I can do and I let you know.
Thanks Felix much appreciated - one less cpuz spd window need to be opened :D
Vive la France, Felix!:yepp:
Off topic: stalker CoP is a great game. :)
Originally I wanted to add one line for spd information, finally I have completely revised the System information Panel:
CPU-Tweaker 1.4 beta9
Let me know bugs/impressions/ideas...
