Yeh, i'm starting to wonder whether i'll have any working components left by the end of the week. If anyone would like to send me some *working* hardware, i'll gladly accept their charity. :p: :D
I have a P3 450mhz you can have it plays dvds and everything. Only stutters a bit, maybe you could overclock it to 500mhz if your lucky :DQuote:
Originally Posted by CD 1986
Lol, thanks bud, much appreciated :D
(wonders about becoming the official XS.org charity case, hehe)
wow sorry to hear that CD, any idea what went wrong? anyways it seems like both our weekends have been crappy :/ my cat is in the hospital as we speak because of seizures, I hope he gets better :/
Hi,
My first post here. :)
Which biosrevision run best on this mobo? I have v1.8.
What do I need to do with the mobo for raise my booster to ~3.5-3.6V.
It is possibly!?
My max oc is 2.5GHz stable for cpu and the memcontroller can run max 240fsb 1:1 (2-2-2-6).....I need to do something!! :confused:
My goal is 250*10 (2-2-2-6).
Proposal??
Thank you,
Pretty sure it's a motherboard issue, possibly a PSU issue, but i used 2 different ones and i doubt they are both faulty! Won't know if it killed any other components (like my new Venice :() until i get the mobo repaired.Quote:
Originally Posted by uniacid
Hope your cat is ok and gets better soon!!! :)
YAY :woot:
Just read some cool news over at MSI user forum. Apparantly the current neo 2 bios cant be modified to support san diego venice fully so they are starting from scratch to make a new bios. The new bios will include lots more options like configurable ram timings and possibly higher vcore options and the 150 183 dividers.
Will take a bit of time to build though but sounds good to me we get a brand new bios that will make neo2 even better hopefully.
thread is here
http://216.239.39.104/translate_c?hl...lr%3D%26sa%3DG
this post sounds the best of this 56pages thread.... hope it is true and comes out fastQuote:
Originally Posted by sideeffect
8x360Mhz 2886Mhz :banana:
I LOVE THIS MOBO!!!!
Nice OC you got... what cooling?Quote:
Originally Posted by Boble76
tat's a good OC.... more details plz?Quote:
New bios due at the end of this month. :)Quote:
Originally Posted by harpyboy
8x360.8Mhz=2886Mhz
Watercooling system on CPU (Swiftech MCW6002-64) & GPU (Only4Pro Magnum), the water was about +20C.
Memories: 2*256Mb Corsair XMS pc3500 BH5 133/200@239Mhz 3.5V
(today I'll get 2 more) :slobber:
Do you wanna know something more?
Link link link .... this makes me so happy!!!!!!!!!!!! :stick:Quote:
(Or is this email?)
patience my young padawan.........Quote:
Originally Posted by nweibley
nweibley: tat's very high FSB u r on... i can't get mine to pass 320.... goshh....
I'm gonna push even more today, FSB365-370 maybe possible?
I need Icewater for the CPU..
Let's hope it won't..:explode2:
Today I'm gonna try to push even harder :sonic: ..FSB365-370
Let's hope it won't :explode:
Originally Posted by Vega
download my cpu reference sheet to see what the best combos would be for your setup, you using memtest right?
the reference sheet is on the previous page of this forum
Hey fellas,
Time for a kinda stupid question, but does anyone know a program that i can use to read the ddr voltage on my neo2? It's impossible to see the readings on the booster because it's inside my case and hidden under the cpu hsf. I have to get a darn mirror out and stick it in my case just to be able to read voltages. I just realised today that i'd been running my ram @ 3.9v for about 4 days! Now that's a good burn in ;). But now the ram overclocks worse than before...
Which brings me to another question... WTF is up with my ram... I got it about 1 week ago (OCZ value UTT stuff) and i have been able to pass 3dmark01 @ 255 2-2-2-5 (at like 3.6v... i think?). The problem is, i went to do some benching today, and now it won't even run through @ 240fsb...
Any help on either is very appreciated.
Cheers :toast:
Boble76: What chipset cooling, chipset voltage and/or vAGP, LDT and which bios are you running for 360htt?
Is it possible, that the highest HT-Speed I get is 240?
A little bit disappointing, i think. :(
Chipset cooling is that small original cooler (50dB) :hehe:Quote:
Originally Posted by TMM
I don't even know how much the chipset voltages are (I can't change chipset-voltage),but I think voltages are "normal" and the BIOS is 1.36b
I don't know, just having fun!!!! :banana3:
whats the LDT multi set at?. If its still at 5x then thats probably whats limiting it. set it to 3x and you should be able to get much more, 300htt is a piece of cake for my board @ 3x LDT and stock volts, cooling etc.Quote:
Originally Posted by mapel110
yea... K8N neo2 should reach 300htt easily...
u sure u not using SATA 1 and 2 ? which isn't locked..
