Originally Posted by
dejanh
This is right in line with what is happening on my end. I found that I have to constantly readjust my memory timings. Very messed up if you ask me, and same as for you, going back to older BIOS does not restore stability. For me this started with 1001 (first time I encountered DET DRAM hang in months of working fine), and now it is a problem every day.
Anyway, left Memtest HCI running as I said I will using all of the memory. Been about 4 hours and no errors at all. I just stopped it now. Here is the screenshot at 1600MHz, 7-8-7-18-1T, 3600MHz Uncore.
Something is very wrong here, and there is no way in hell that it is the PSU. Maybe a more powerful PSU will make the symptoms disappear but I really doubt that anything gets fixed here. Something else is causing this, and I do not think that this is a small problem either.
EDIT: Can somebody answer this for me please...
What happens when you shut down the system for a longer period of time that does not happen when you just shut the system down for about 1 or 2, or even 3 hours? Keep in mind that no power is removed from the system at this time, nothing is shut down, unplugged, nothing at all changes. However, booting after 8 hours is a no go, but booting after 2-3 hours is always a go...
There in lies the answer to this problem, but I do not know what exactly happens, and therefore I cannot get to the bottom of this...please fill in some info to the best of your knowledge.
