Felix,something is wrong.
Me too "NOT FOR THIS SYSTEM!"
Ver. 1.3 beta 3 and 4 is OK.
http://img163.imageshack.us/img163/3...1130161335.png
Seems Lynnfield lost support.:confused:
=>stasio: could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr
Thank.
...OK, fixed in this version: CPU-Tweaker1.3.zip
Thanks Felix,now OK.:up:
What is this program for? To change the ram timings without having to go in the bios?
Bah... it doesn't let me lock the multiplier at 21x on my ASRock x58 deluxe.
I can only get 21x if turbo is enabled.. and that defeats the purpose as it clocks down to 20x as soon as I load up the CPU.
i can't change timing using the lastest CPU Tweaker (1.3 final i think) all of the button is OK (nothing is grey out) but the timing just stay still. Pls help!
Mobo: MSI P55-GD65 BIOS 1.5 - CPU Corei5 750 - CPUz 1.5.22
I just wanted to report that when I change tRFC from zero to a known working value the system reboots instantly, no BSOD (XP Home Eddition SP3 with latest updates.)
It would also freez if I change from a working value to zero, but this is a lesser problem as this would happen when changing to a too low value anyway.
If this is a common problem, I think disabling tRFC from changing when zero will help.
EDIT: report is for MemSet
I dont think that it's the program at fault but rather the board
i'm working with MSI on this......i think they might actually have the ram table locked because even MSI software is unable to change values on the fly in windows from what Raja told me from Anandtech......
=> keba: dinos22 is right, PCI configuration space is locked in the bios on your board, I can't do nothing.
=> Chike: what is your board, and what is the tRFC value in your bios when memset indicate 0?
I'll grayed out the tRFC combo when it's indicate 0 in a next beta.
CPU-Tweaker 1.4 beta1
-Fix the bug when aero is disabled if CPU-Tweaker is open on AMD CPU under Windows 7;
-Add some chipsets ID detection;
Merry Christmas to all! :toast:
Thanks Felix,Merry Christmas to you!!!!:up::banana3::party:
P55 with 32nm Intels does not to work ...
Memset work on Clarkdale CPU, but not CPU-tweaker.
Is it possible you to make a registers dump (with cpuz->last table->registers.txt) on a Clarkdale
Thank.
HI Felix,
There's a user with memory problems, weird thing is main MemSet window shows "DDR3" with some combination of ram installed.
I wonder if this is related to his problems or is it just a glitch in MemSet.
Could you take a look at the images in http://forums.tweaktown.com/f69/ques...tml#post340763
He says the same with vers. 4.1.
...I'm working actually for add support for Core i3 in cpu-tweaker, but I'll try to fix it (and tRD problem) soon.
...fixed in this version: MemSet41.zip.
For P45/DDR3 detection, I need to get some info.
