gigabyte MB's have this thing where you can set say
1.18-1.20-1.206 and in cpuz it just stays at 1.16
and 1.218-1.22-1.225 and cpu shows 1.18v
at least on all my ep45-UD3P/R's it did and im
assuming its the same on this board too.
yea its a gigabyte thing.i used to see people,just an example
in cpuz thier vcore was 1.19 and im like what the hell how you getting 1.19v
because mine went 1.186 to 1.20.but then i realized they are using different
MB's asus or evga or biostar,each have different increment scales
Yep the bios changes vcore in increments of .00625v but the sensor on the mobo which cpuz is reading reports in steps of .016v. So you have to go up 2-3 steps to see the change.
Just had a look back at your posts radaja, that is one mighty fine chip you have got there mate!!
Wish I could get my hands on a chip that could run on those kinda voltages.
im just glad it works,well im also mighty happy that its good too.
but after i got it and my dfi board and couldnt get it to prime at stock settings
i thought the worse,that it was going to be the cpu because everything is inside
now(IMC)and then seeing imo's cpu i thought great ive got a great batch but ill
never experience it.but alls good now.
BTW thanks blunt
Another update. Batch #3910A372. :) I was very stoked when I woke up this morning to find it still going. This is on air.
CPU 1.368V
QPI 1.35V
PLL 1.82
IOH 1.18
http://img528.imageshack.us/img528/7156/4300i7.jpg
I test my I7 920 D0 3837A765
at 4113
http://img42.imageshack.us/img42/1657/41131224v.jpg
at 4523
http://img27.imageshack.us/img27/4794/45231424.jpg
nicely done. 4.5 GHz at 1.424v is not bad at all considering its actually stable. Not just bench stable.
Wow, you guys are way better at this then me. I was proud to get 4ghz @ 1.264v. Now I feel like crawling back to my computer room with my tail between my legs.
4GHZ is still quite awesome Scott. :)
settings so far
3919A707
4.3ghz
http://i107.photobucket.com/albums/m...ntitled-13.jpg
Ver nice billdavis how many cards? Nvidia or Radeon? Model? Brand? Settings?
Was wondering would you be kind enough to lend me 1 3Dmark to make mine a round figure :D
http://img18.imageshack.us/img18/5015/15999.png
Nice score lol i was thinking on getting the PROLIMATECH for my D0 what do you guys think? or with less money i can get something similer?
Finished tweaking my clock so time to add to the database, more to come from this yet :up:
Batch# 3850A795
Bios Settings:
Vcore: 1.2875v
Vtt: 1.325v
IOH: 1.2v
PLL 1.8v
Vdimm: 1.66v
Cooling is HK 3.0, MIPS NB/SB/NF200 and 2x MIPS Mosfet blocks on P6T6 WS Rev, DDC 18w, 120.4 Thermochill rad
http://i207.photobucket.com/albums/b.../paulstest.jpg
Hi- someone he met fpo / batch in the i7-975 EE-3924A401?
heres my latest.
202x21@4242 ddr3-1616 7-7-7-21
Batch# 3849B018
Bios Settings:
Vcore: 1.206v bios/1.16v load
Vtt: 1.30v
IOH: 1.14v
PLL 1.8v
Vdimm: 1.68v
prime95 blend
http://i33.tinypic.com/256xru0.jpg
everest
http://i34.tinypic.com/m8h568.jpg
im having problems getting 20x210@4200 with turbo and HT off.
any advice
I don't get memory speed even near that Radaja. Anyone have any ideas why? Not the latest version of Everest perhaps?
http://img237.imageshack.us/img237/7564/wtfh.jpg
Check your timings.
Thought my timings were pretty good.
Cas 7 against cas 8? :shrug:
Do you get same numbers on retry? Everest has a tendency to report "wrong" numbers once a while, but reports "correct" mostly. But in case it would report too high, and I have never seen it to report too low (at least on system).
Your numbers are too low for your Uncore and timings. It seams to be off by about 3000MB/s(read). something seams to be wrong, but it is not easy to say what from a distance. You can try to bench with higher Vdimm to check if it is a hit&miss.
It seems to be right around the same no matter how many times I refresh. I will try upping the dimm voltage and report back. Thank you.
*Edit* Going from 1.66 to 1.68 did absolutely nothing. I have been trying to nail this down for a month now. :(
If your RAM can't handle the speed, (and sometimes raising the Vdimm wouldn't help either), then you can get bad results. Have you tested the stability of the RAM and IMC (with memtest or similar)? Take a new HyperPi32M run anyways, it will show the problem fast.
You can also try to bench with x6 RAM @6-7-6-22 (or something similar), but try to keep the Uncore at the same x16. Just to see if you can get better numbers.
