uninstall the nforce drivers
Originally Posted by
SlayeRC
My current rig:
- 780i ASUS Striker II Formula
- 2 x AData Extreme 800+ DDR2
- 2x 8800GTX ASUS
- 1 x ASUS Xonar PCI
- Enermax 720W
I changed the motherboard in the first place from evga 680i to 780i and booted old vista32 installed with the evga and vista recognized all the new devices. My surprize was that ethernet ports was not functioning after resume from sleep mode. I did not know what happend in the first place and i suspected the nforce drivers were not good because they are not certified for 780i.
I started with fresh install of vista32, formated the vista system partition .. , installed the recomended 9.46 drivers from nvidias site and everything worked, until the next resume from sleep mode :D , after this resume i have no luck reviving my ethernet ports. Vista is sensing if the ethernet port have link or not (if i plug out the cable) but i have no received packets !!!
I have no errors in device manager, event logs are not containing problems regarding the two ethernet devices. I even tried disabling all the unused devices like HD Audio and firewire. I tried all the bioses from ASUS support site including the latest 902 but no change. :brick:
Nforce 780i drivers that i used are:
nForce 9.46WHQL Certified
Version: 9.46
Release Date: December 17, 2007
Operating System: Windows Vista 32-bit
Language: U.S. English
File Size: 43.1 MB
:shrug:
windows will work it then u wont have a problem with that keep Nforce off your pc i have s2f 8800 GT OC ocz 2 gig ram 64 bit e6750
