I'll get back to you all in a bit, just found some free time.
I heard midday today that there is a Phenom FX CPU yet to release within the next 3 months. FX-82 it was dubbed. Have yet to check online on it yet, will do after I start-up Phenom and flash the P0H you guys flashed.
[EDIT]
Yep, I'm sure there was such a model. Whether it'll still release or not, I'm not sure. No motherboard manufacturer lists Phenom FX compatible until they've fully tested and verified samples of this product. Infact, check out what I found listed on MSI site for our board:
Attachment 72816
Bit of a giveaway that. ;)
Guys, the BIOS file P0H aGeoM attached is fine, checksum is also perfect. I've flashed it without even setting defaults although I did follow the safe known procedure and did use the flash parameters.
http://img167.imageshack.us/img167/9486/poh2bz6.png
Heck, look at my lowest voltage 2700MHz boot so far... (no crashes)
Attachment 72815
It is safe and working. Looks like the method being the root error. :(
1.30 official release is based off P0H fully.
Jaivan: no DFI in this country, one I briefly tested is gone back to DFI for some reason so I have to get the Sapphire instead. I can get hold of the Sapphire, which is DFI half rebadged.
