im using LLC1 man so other friends check back and please before doing such comment post 3hours of prime the new one at least :up:
thanks sergio we could just ignore him for not showing proof of stability
Here is explanation:
http://www.xtremesystems.org/forums/...d.php?t=267412
Every 0.01 Vcore increased, you get 100MHz more! :shocked::ROTF::rofl:
Get ready you UD7 guys, incoming!
1st P67 B3 mobo seen around here. :D
http://i755.photobucket.com/albums/x...3/2b10fde5.jpg
http://i755.photobucket.com/albums/x...3/d89cab71.jpg
http://i755.photobucket.com/albums/x...3/4a175cbb.jpg
Slate wiped clean with fresh new F1 BIOS?
Well, looks like the stock F1 BIOS on the new B3 mobo is quite nicely matured for some overclocking, so far no strange quirks seen yet.
http://i755.photobucket.com/albums/x...3/95ef8606.png
http://i755.photobucket.com/albums/x...3/65f248e7.png
Nice! :)
Interesting. Anyone know if B2 BIOS can be used on B3 and vice versa? Cant see why the BIOS would be different, it is probably the latest official B2 BIOS renamed.
quite being such a tool. . .
wheres your screenshot? oh ya you don't have one because your :banana::banana::banana::banana: isn't really stable.
sergio has been here for a lot longer than both you and I so show a little respect:shrug:
edit: after seeing your other post on vcore and multi, it makes much sense your a nub:rofl::ROTF::rofl::ROTF:
Using llc2 allows you to run lower idle vcore, it looks better in a cpuz screen showing 4800mhz 1.39v vs 4800mhz 1.45v. However when you put the chip under load your vcore will go above 1.4v if you are using 1.39v bios and LLC2, yet you insult someone who's chip needs roughly the same vcore load as your chip because he chose to use a different LLC option. :shrug:
This is about having fun, learning, and helping others, and not about insulting people.
thanks bud the first thing he did was insulting without proof of notha
thanks mate i learnt LLC1 from you and its best LLC2 unstable and peaks really bad for 24/7 use guess for bench is ok, either way that guy insulting its really desapointing...makes me think of someone...mazda lol
cheers all :up:
Sergio
@MacClipper: so the boards are in Singapore already. Nice...
Assume F1 new bios for the b3 stepping mb is in fact the old F7 from b2?
