Fine ta :up: Just gradually getting my stuff together to try i7 920 , but enjoying this board in the meantime. :up:Quote:
sorry i really don't want to sound like i know a lot, because i'm not. but don't judge your 8GB ram system overclock with Everest's score, you can't compare the read score with 2x1GB that can run a low tRFC like 25-30. may be you may want to use other tool like a SuperPi 32MB run and compare it with your previous overclock.
trust me you know quite alot,i was just frustated that i was getting 11000w/write/copy and just falling short of 10000/read(always 9950. but i tried lowering trfc to 55 and got it to 10000.
Anyone know how to solve the problem between the Strap 2:40 and MCH Volt above 1.440? I really like this strap but to not be able to raise the MCH voltage is just a pain.
Finally started to play with this board again but can't find anything on the volts measuring points, wanna take multimeter reading to calculate the references %.
Anyone wanna share this info? Maybe older Gigabyte boards share the same spots for vcore, vmch, vdimm etc?
i would like to know that too.also does anyone know whats the optimal way to set my pagefile system when using 8 gigs of ram?im not very well versed in the software side of things,but from what ive readthe paging file is space used on the harddrive as if it were ram, right. so if i have all this extra(task manager shows 1.34gigs being used)wouldnt it be better for my system to use the ram instead of the harddrive?isnt the ram faster?or do i have this all wrong? someone here must know this kind of stuff,i surely could use some advice on this issue. thank you
Stasio was kind enough to send this link:
http://www.clunk.org.uk/forums/revie...html#post42137
It's for the UD3R but will do.
:lol: was just about to give you link them i saw ^^^^^^^ :rofl:Quote:
Originally Posted by Jor3lBR
Should I disable for enable LLC?
When I enable it, I don't get any vdroop. So is there any down side to having LLC enabled?
@ Jor3lBR / Hey Bro, I'm comming for you :up:
http://valid.canardpc.com/cache/banner/485355.png
:usa: 2rd Place Q9650 WR :usa: Freq : 5013.22 MHz (557.02 * 9)
Hi Guys,
Decided to bench on AIR with a normal priced air cooler (below$35) to keep peoples hopes up on this amazing cpu.
All low volts for people that want 24/7 use: 1.376vcore, 1.400vtt, 1.57pll, 1.40vnb, 1.20vsb (except ram that I needed more juice to keep tight timings and 5:6 strap).
[System Setup]
CPU: Q9650@4400Mhz 489x9 1.376vcore on load and idle 1.40vtt
Mobo: Gigabyte EP45-UD3P
Cooler: Sunbeam Core Contact Freezer
Ram: 4gb G.Skill Pi 9600
Video: X1300
PSU: OCZ Powerstream 520w Adj
[Setup Pics]
http://i44.tinypic.com/1zzt3ld.jpg**************http://i44.tinypic.com/2aj5s2c.jpg
[BIOS Template for Gigabyte Users]
Code:******Gigabyte EP45 UD3P******
Q9650 489 X 9 4401MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.35GHz...........................[ 489 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 489 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 333MHz ]
System Memory Multipler.........................[ 2.40 ]
Memory Frequency 1066...........................[ 1174 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ 52 ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 7 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ OC-1333 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
Static tRead Value [ 6 ] ................[ 8 ]
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.23750 ]...................[ 1.41250 ]
CPU Termination [ 1.20 ]...................[ 1.40 ]
CPU PLL [ 1.50 ]...................[ 1.570 ]
CPU Reference [ 0.766 ]...................[ 0.871 OR 0.886 ]
MCH Core [1.1 ]...................[ 1.400 ]
MCH Reference [0.760 ]...................[ 0.926 ]
MCH/DRAM Refernce [0.900 ]...................[ 1.150 ]
ICH I/O [1.500 ]...................[ 1.570 ]
ICH Core [1.100 ]...................[ 1.200 ]
DRAM Voltage [1.800 ]...................[ 2.300 ]
DRAM Termination [0.900 ]...................[ 1.150 ]
Channel A Ref [0.900 ]...................[ 1.150 ]
Channel B Ref [0.900 ]...................[ 1.150 ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Disabled ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
[Stability Test Prime95 Blend]
3 hrs Load:
http://i40.tinypic.com/2iusrhv.jpg
11 hrs Idle:
http://i40.tinypic.com/302ti04.jpg
Hope this helps Q9650 and Gigabyte UD3P users! :up:
Nice work :up:
I wish I had a Q9650 :(
that's really nice, Jor3lBR.
and thanks for sharing your settings.
@Jor3lBR
great work and system
I have an E8400 I'm trying to get stable at 4ghz. It fails Orthos after 17 minutes. Here is a list of my settings. Any help would be appreciated.
******Gigabyte EP45 UD3R F5 Bios******
E8400 445 X 9 4005MHz
CPU Clock Ratio....................................[ 9 ]
Fine CPU Clock Ratio...............................[ 0 ]
CPU Frequency ...................................[ 445 x 9 ]
CPU Host Frequency (Mhz)........................[ 445 ]
C.I.A 2 [Disabled]
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
MCH Clock Skew..................................[ 150ps ]
System Memory Multipler..........................[ 2.40 ]
Memory Frequency 1066...........................[ 1068 ]
DRAM Timing Selectable............................[ Manual ]
tRCD.............................................. ....[ 5 ]
tRP............................................... .....[ 5 ]
tRAS.............................................. ....[ 15 ]
tWTR...........................................[ Auto ]
tRFC............................................[ Auto ]
Command Rate (cmd)......................[ Auto ]
Static tRead Value [ 8 ] ................[ Auto ]
DDR Write Training..................................[ Auto ]
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level.................... [ Auto ]
cmd Driving Pull Up Level......................[ Auto ]
ctrl Driving Pull Down Level.....................[ Auto ]
clk Driving Pull Down Level......................[ Auto ]
CPU Vcore [ 1.25000 ]...................[ 1.3625 ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ Normal ]
MCH Core [1.100 ]...................[ 1.300 ]
MCH Reference [0.760 ]...................[ 0.743 ]
MCH/DRAM Refernce [0.900 ]...................[ Normal ]
ICH I/O [1.500 ]...................[ Normal ]
ICH Core [1.100 ]...................[ Normal ]
DRAM Voltage [1.800 ]...................[ 2.200 ]
DRAM Termination [0.900 ]...................[ Normal ]
Channel A Ref [0.900 ]...................[ Normal ]
Channel B Ref [0.900 ]...................[ Normal ]
No-Execute memory Protect.....................[ Enabled ]
CPU Thermal Monitor.............................[ Enabled ]
Virtualization Technology.......................[ Enabled ]
Hi amwhitey,
The bios settings for these clocks are in the links below, for the ud3R, may give you a guide:-
E8600 4,160 8x520@2B 1,040Mhz 5-5-5-14
E8600 4,260 8x533@2B 1.066Mhz 5-5-5-14
luck:up:
I was able to run my Q9650 with the Xig direct touch at 4.5 @ 503 FSB and it was grerat, bvery stable, I never ran 11 hours of that stuff, but did all the futuremark stuff, and played a lot of games, I love this board adn CPU.... Q9650 and GIG UD3P :surf:
Thanks Supershanks for the settings. I'll give those a try and see what happens.
Jor3lBR,
i just took a peek at your bios setting (above) again, it seems to me that your DRAM setting is might be too tight?
did you try setting memory timing differently to see if you can lower the DIMM voltage down to may be 2.1-2.2v?
i don't have a Q9650 and the ram kit, or i would check it out myself, i'm just wondering is this overclock really need to use 2.3v on the dimms?
Yes it does if you want to use the 2:40 strap. Max Vmch that strap offers is 1.40vmch.
The rams are fine 2.3vdimm on BIOS = 2.25vdimm Real on Dmulti and 2.28vdimm shown on the ET6.
I would try PL7 1:1 strap latter to see if there is a big loss.
My OC testing begins isolation any ram errors, Config BIOS > Memtest DOS 2 passes > Memtest windows 150% > then I go to small fft's 8k and 10k if passes I will blend it above 3hrs.
Anything less on the Ram would give Memtest #7 errors. I will play with the other options too and see if I can discover anything else. Today I lowered the DRAM Terminations and References to below 50% a bit and could reduce vdimm a bit.
But if you have a 120mm fan you will be good till 2.4vdimm (probably 2.35 real).
you probably need to use more NB volts. i'm sure 2.3-2.35v is fine for the kit, but like i said i'm really wondering why it has to be this high.
for the DRAM settings itself, if you willing to try something new, there are a few different settings to try.
but since i don't have the hardware (especially the GSkill 9600 PI kit) i’ll have to let you discover them.
i would say try using XMP profile and leave the 2nd/3rd timings in the Advanced settings to Auto, don't set the Drive Strength Profile, diable the DDR Write Training on both Ch A & B
and then also try setting the Extreme Memory Profile to Auto, but set all timings manually in the bios.
i still use 700mv/700mv at the Advanced Clock Controls for my 500fsb, no Clock Skews settings everywhere, but my CPU is Q9300
2.3-2.35v in BIOS is not real panging as I said I got Digital Multimeter here that shows my Ram below 2.26v.
Dunno if you read my entire post but I'll say again MCH Voltage on 2:40 Strap is broken on all Gigabyte EP45 UD3 series boards and thus far there is no fix for it, I would need at least 1.5mch to lower vdimm to 2.1 or 2.2 but it's stuck on a max 1.440vmch because of the strap problem. If you put MCH voltage above 1.440 results in a no post condition...
Yes I just discovered that lowering the Dram Refs and Termination will allow you to lower Vdimm, I'll try few things you suggested too. :up: Thanks.
