2xSATA + 2xSATAll on ICH8R (yellow), AHCI enabled, working fine.Quote:
Originally Posted by aldamon
Go back if you wish, but you could also try applying 'optimised defaults' first and then reconfiguring your F5 BIOS settings.
what is the purpose of AHCI? do you need to install drivers when loading windows (hit F6) when using this mode?
Good for you. :rolleyes: At what FSB is everyone "working fine?"Quote:
Originally Posted by GAM
No bios updates then?
nothing as of yet :(
400 here. Will probably play around with it again over the weekend. I'd like to be stable at 450 if possible, but quite happy either way.Quote:
If u flash in windows ( gigabyte bioswriter ) u must put a checkmark at Clear DMI data pool.Quote:
Originally Posted by Jaim3x
Im @ 458.....Quote:
CPUz shows F3 for my BIOS, when in fact im using F5? What the hell..... On the POST screen as the PC boots, it too says F5?????
I have to use F4 for everything to be fine. I thought I could get by with F3, but it froze my mouse after inactivity. F4 is perfect. No missing boot disks. No missing X-Fi at 451.Quote:
Originally Posted by newls1
I had to revert back to the F5 BIOS, F6 was terrible.Quote:
I'm currently at 400x8 which seems to be a sweet spot for temps and speed...
Same here.Quote:
Originally Posted by eXceededgoku
When you're in the QFlash menu in the BIOS you need to uncheck the save DMI pool data option before flashing.Quote:
off topic but:
I gave up on the DS3 and bought an Asus P5B Deluxe and guess what - my G.SKILL 2GB HZ now runs error-free@DDR2-1000 specs at 4-4-4-12 and 2.3V (on the DS3 I could get a max of 920-930 approx,tried all BIOSes, settings and such). Also my CPU (E6300) now runs @3,5GHz (but @1.525V unfortunatelly so I might go lower because the CPU is getting quite hot - 70C in Orthos, this seems a lot to me).
So anyone on a DS3, do yourself a favor and sell it ASAP and get the P5B DELUXE ;) The DS3 is a good board but not good enough for hardcore overclocking IMHO - already 450MHz FSB the board was making screeching sounds when Orthos was running. The P5B Deluxe, on the other hand, is really rock solid thus far and also doesen't make those dreaded screeching sounds. Btw, it took me around 30mins to setup a stable 500MHz FSB system on the Asus :clap: But your mileage may vary of course :bounce:
If you intend to use NCQ, hit F6 when install Windows XP....Quote:
Originally Posted by JohnnySK
we all knew about this , or atleast anyone who read 1/10th of this thread. or the other 10 threads about this.
we keep it cuz the P5B is only going to get you the higher ram which doesnt give you much performance at all, and maybe a slight higher fsb. which again is only a slight increase.
or.. people cant afford to buy another board.
Same crap with F5 :( Goes from 8x390 to 8x400 without a problem then when i shut the computer of for a while its restart restart restart and CMOS all over again... What to do. Can it be something with the settings?? Still does 8x430+ if I clock with EasyTune....Quote:
Originally Posted by laziepig
Im so sick of this.... now help me....
The main reason I enable AHCI is to 'hot swap' drives. In my case, I have 5.25" removable drives that I use for backups and the like. AHCI/SATAII functions allow me to switch on/off, mount/dismount and 'swap' these drives without having to reboot.Quote:
Originally Posted by jugeen
The price difference between both boards is the main thing here, right?Quote:
Originally Posted by Lestat
Proof of a new revision of the DQ6:
http://vic.expreview.com/attachment/1159544630.jpg
So what's different? I can only notice that the top heatsink/radiator fins are cut differently, tapering off to a smaller profile.Quote:
Originally Posted by Richard Dower
Exactly, design has changed.
So Rich, have you found out what else has changed or might be different?Quote:
The board still says revision 1.0, i *think* it comes preloaded with F4 bios. Most likely the ITE and JMicron have a different build date.
Hard to tell without close ups of the mobo.
