....from where?.......:DQuote:
hmm Tarosa is using a PCI video card...Quote:
Originally Posted by PRTeamJapan
That might be it maybe?
I havn't noticed anyone else using a PCI-E card and has gotten past 240FSB?
No i also use a 4mb pci..
If fred tells that tarosa and tam dont have an rev 00A board... i know the problem.
:eek: :eek: :banana: :banana: :banana: :banana:Quote:
why is bios not accessible if windows is OK :confused:
guys have you tried the PCI Express frequency trick Hirpo suggested for more FSB?
No i allready tried.
follow this thread for the problem http://www.xtremesystems.org/forums/...ad.php?t=95834
Hahaha, Tarosa just came back to OC after 5 years absence-- I bet he was busy collecting these DDR2 while he was sleeping:DQuote:
Originally Posted by hipro5
@Waus-mod
AFAIK, the Rev of retail M/B came into Akiba last week is .00A as shown KUBOKUBO
And tam and tarosa?
I highly doubt they got other revision for their M/B b/c they bought them at the same time.Quote:
Unless AOpen mixed other rev in the same shipment-- is that what you susupect?
newegg is showing 1066fsb support... you guys might want to give aopen a call, these boards did cost you a LOT.
it would be nice if results were posted on original page as that looks how it was originally planned.
yes.. i think the rev 00A is fsb stuck and a other not.. so i hope you can ask if they are using an other rev.Quote:
Rev 00A I haveQuote:
By next week hopefully most already get their board:) @ least here in US.
Boards and T2600ES combo will be on sale here @XS probly by Fri.(from some members)
A few etailers will carry the board by weekend and I will try to get xtra boards for whoever needs it.:toast:
Originally Posted by Dumo
You got one mobo.:toast:
denisb@hwluxx retail aopenboard delivered yesterday in GermanyQuote:
seems to have no probs
@mine what revesion board + bios do you have ?
Also what stepping cpu?
its denis.bodes board--bios is R1.03 - board retail aopen GermanyQuote:
Originally Posted by ibby
stepping 8
could you please look between the dimm solts and get the revision number of the actual board as wellQuote:
Originally Posted by mine
may say A00 or A01
which store?Quote:
Yep, they all have Rev 00A.Quote:
http://www.geocities.jp/gbxfs134/i97...G/DSCN0382.JPG
BTW, where is your setup details?
If you are asking so many questions, you'd better tell us.
The issue may be due to other than M/B itself.
By New Beetle
(Set up)
M/B:AOpen i975Xa-YDG Vmod / BIOS:R1.02
M/B Bed:「V-TEC ARC Bed Rev.3.3」
CPU:Core Duo T2600 / QHJJ ES 7530A497
CPU Cooling:「Kuri Pro2」+ DICE
Chipset Cooling:Normal
Memory:CORSAIR 5400C4 512MB x2 / CL4-3-2-8
VGA:ATI XPERT 98 PCI 8MB
HDD:IBM-DTLA-307030 / U-DMA 5 (ATA100)
PowerSuplly:Zippy-460WS #2 (3.3V Rail Mod)
Vcore:1.600V/ Vddr:2.15V/ Vio:3.29V
OS:Windows Server 2003
Remarks:DICE Cooling / FSB240MHz Boot / Graphite sheet
http://premium1.uploadit.org/fredyam...New-Beetle.png
Edit: Image link fixed
wich revision mine"? rev00A?
@ fred.. i will give my info asap
00A
yeahh i heard from my contact there is only a rev 00A
