Link no workie. =(
Any chance of a known person around here posting their copy at a replacement link?
Or perhaps this outage is temporary.
i am running 4GB (4x1GB) at unlinked 1600MHz 20-7-7-7, at 1800MHz are not stable ...
Hi, After reading yesterdays posts I went home and made some changes to my settings :-
LLC : ENABLED to DISABLED
CPU V : 1.3875 from 1.3275
PLL : 1.56 from 1.50
(VTT was already 1.36)
Before these changes every time I started windows I would get a Norton pop up telling me that my virus definitions were out of date even though they were the latest available. Also, once I had to re-activate it and randomly re-authorise the computer to play my iTunes.
Now it is fixed !! - I made the changes above at the same time so not sure is it is down to LLC or increasing PLL but thanks to Hurin, Slim & RasCas.
Drivers working for me are graphics 177.41 (250+ 3dMarkVantage points) and chipset 9.64 as I can't enable teaming with 15.17.
My rig :QX9770 on Thermalright Ultra 120 Extreme cooler:
EVGA 9800 GX2 SSC. Creative X-Fi Elite Pro.
OCZ 4x1Gb PC3-16000C9 2000Mhz Platinum EB
Samsung F1 1TB & 2X500Gb Hitachi SATA 2.
2xSamsung 20XDVD-RW SATA
Vista Ultimate 32bit
Settings : 430x9.5=4085Mhz overclock. 1720 FSB Syn & Linked.
Mem : 7-7-7-22-30-1T @ 1.9v
Benches : 20,419 3dMark06 7,274 PCMarkVantage.
Hello guys,
Some news about the new bios 0901 ?
I still have SLI freeze in videos with 0704 and i haven't try bios 08xx.
My stuff :
Asus Striker II Extreme
Intel Q9450 @3,2Ghz FSB 1600Mhz
Zalman 9500
Corsair 2Go DDR3 1600Mhz CAS 7
SLI of MSI Geforce 9800GTX OC
WD Raptor 150Go 10 000tr/min
Seagate Barracuda 500Go
Updated to 0901 from 0804 without any issues so far. Running a GX2 so not two cards in SLi. Have seen an earlier post saying that 0804 has cured SLi video corruption.
Slim, do you give up on helping other SLI freezing users ? :(
You should have listened to me 1 month ago, than you would already be a happy man with a good board :rofl:
( 06-13-2008, 08:17 PM post#941 ) :D
Anyway, good job to RMA the damn thing, if it's broken don't try to fix it, just RMA.
Hope you get more luck with your replacement :up:
I know a lot of you are having problems, and I really hope you get them sorted, but so far my SIIE has given me very few major issue's, although one or 2 oddities which I'll get onto in a in. Ive not had any corruption issues, no SLI freezes and everything is working pretty good... i keep half expecting something to go wrong everytime I switch it on! LOL! Anyhow, I got my CPU stable at 4ghz on this board:
http://img110.imageshack.us/img110/1...ablecrogy7.jpg
There was an FSB hole around 400mhz (on previous boards ran 400x10) and i coulnt understand y it wouldnt even get to windows! Anyhow, solved that by dropping the multi as u can see :)
Now for an oddity - wanna run this past you guys. Tonight ive been trying to tighten up my timings, but I set them in bios, it posts with the timings I have set, but then everything in windows reports them as not change - with the exception of CAS. In the shot below, its set to 7-7-7-20 in bios, and on the POST screen thats what it displays. This is 0901 bios. Any ideas?
http://img113.imageshack.us/img113/8...ryissuewy6.jpg
I didnt give up, didnt you see all this days I was trying to fix this? :shrug:
I just hope I did the right thing and that this time I get a board that will let me use SLI and be stable with my OC with no corruptions.
At least I have some good news, IM GOING WATER COOLING :bounces::bounces:
Just watch me coming back in 2 weeks
@MikeMK
can you post your settings?
Settings are as follows:
Multi: 9
FSB Mem Clock Mode: Linked
FSB Mem Ratio: Synced
FSB (QDR) 1780 (SDR = 445mhz)
LDT Freq: 4x
vcore: 1.32v
CPU PLL:1.54v
CPU VTT: 1.3v
Memory: 1.84v
NB Core: 1.58v
SB Core: 1.55v
CPU GTL Ref0:+42mv (I had one weaker core)
All other CPU GTL's @ Default
Memory timings were all at auto for the prime run, as i said in my last post, im just tightening them up now, but having probs with them actually applying properly. Hope that helps :)
I have a question for Justifire if your around?
I see here http://bandwidth.se/thumbs/nouser/img080047c7ab84.jpg you are using thermalright mosfet coolers, but you dont mention in your post which ones? Could you let me know? Did they fit ok out the box? Also, is that an evercool VC-RE on the SB? Cos i have one lying around here that I could use. Just thinking of putting my MCW30 on that NB to cool it down a bit more!
Thanks man, Im really interested!
Btw this is what Im going to be using
Water cooling
CPU Block: D-TEK FuZion v2 CPU Block
Radiator: Feser X-Changer Dual 120mm Xtreme Performance
Pump: Swiftech MCP655B or Liang D5
Barbs: Bitspower Premium G1/4" High Flow 1/2" Fitting - Black Sparkle
Clamps: Breeze Miniature Hose Clamp 7/16 in. to 25/32 in
Reservoir: EK-Multioption RES 250 Rev 2
EK-ANTI-Cyclon for EK Reservoirs
EK Spare Reservoir Holders
Fillport: Danger Den Aluminum Fillport
Water cooling CPU+NB (with stock fusion block) of course with some Fesser coolant and Tygon tubes. I hope to have all of this by the time my Striker arrives :)
just make sure you use good tubing on the Fusion block. the stock ones leak way too easy
Yeah thats why Im using those Bitspower barbs and Im going to be getting clamps from sidewinder just to make sure no leaks there. I paid a lot for that motherboard and taking out the heatsinks is just ridiculous. Besides, that Republic of Gamers logo looks really nice :)
one from the back...don't ask how long it took or how many zip ties were used lol.
Thats a nice build trigger!!!
can someone help me out a bit with an explanation?
I'm a little unclear about how CPU GTL Ref's work. ATM im at 4275 ghz. Core 0 is prime stable for 30 hours the rest fail between two minutes and 3 hours after the test starts.
Second question:
Using core temp I'm seeing max temps full load for each core around 64C, and PCprobe shows my CPU temperature at 40C full load. Is there a reason for the difference in reported temps, or is it just thermal differences between where each core temp and cpu temp are taken?
is this the right place for this post? I have a Q6600 CPU and can only overclock it to 3.0 Ghz i.e. 333 x 9
I get a good score on 3D Vantage
http://service.futuremark.com/compare?3dmv=211942 P 14,300
http://service.futuremark.com/compare?3dmv=211982 E 42,108
The main part of the high score comes from the Physx boost related to the 177.39 driver and abit of the overclock. I can run the RAM at 1555 Mhz however I'm not sure if this helps if I can't get the motherboard over 1333 Mhz.
Has anyone OC'd this Motherboard to higher than 3.0 Ghz with this CPU? If so what settings do I need?
