Any block from EK will be better than luna - that i can say. EK Supreme LT was about 3-4 degree better, EK Supreme HF ... the king of performance ;)
So if you thinking about new block for cpu - check out EK :up:
http://www.abload.de/img/10a329g.jpg
Malik
luna's blue led looks so good. I wonder if I could do that for ek too.
Which brand motherboard block you like a lot?
Here you have EK with led:
http://www.abload.de/img/uv1y0ij.jpg
If you want high performance and very good quality - EK is the best choice for now.
Man your photos are awesome!
But the supreme LT dont perform so well . . .
Really nice malik!
This ongoing log of your work has been the biggest inspiration to me since I decided to watercool my project a few months ago. Your photos are amazing! The fact that you run all of this on one DDC is blows my mind. I'm hoping for two things with my project:
1. The rads I have are enough to cool everything
and
2. My build turns out even remotely close to 1/16 the quality and cleanliness of your build
Can't wait to see more!
-TadZilla
Thanks for big words about my project's :)
All the time i'm thinking... with or without ram block:
http://www.abload.de/img/12boe4.jpg
For me ... something is not ok.
What's your opinion ?
nice shots Malik!
The QPI block is missing. Can you turn around the angel on the graphic card, so that the fitting is looking to the fitting of the mb block?
In my opinion with the RAM Block. I love that one:) what size did the thread has? 3/8 or 1/4?
IMO, you dont have to use the vga ram block, its kind of bulky
So 1-1 in opinions ;)
I have only this photo with ram block :(
Know that ram block (normal ram) is useless, but is nice and it dont bother.
Butttt the vga ram block its too much really. It makes the middle of your board a big mess. Also adds a lot of weight to a single vga and lets face it, the vga back ramps with a simple backplate are fine.
Thats my extended opinion :p
If you want remove both, it'll be more clear.
hm ok, thats right what you said. The graphic ram block looks so nice, but yes, it takes a lot of space. A clear black or nickel backplate could also be very nice.
But i love the Ram cooler of Barus ;)
And here ... you don't have right. 12GB Corsair Dominator with stock radiators are very hot after 1-2h of working. I check this before i install ram block. If i put ori cooler ( this one with fans ) - then temps are ok.
That's why i decide to mount ram block by barus. He looks very nice, and he has good performance.
I decide to make custom backplates for two cards. Chrome look ... with EK logo and something more.
...or you buy a 2nd ram cooler for the 2nd card... but only one cooler doesn`t look very decent, somehow like unfinished.... so either 2nd block or you go on with your custom made blackplate!
..then I should get a PM from you... :D about the block, i mean...
are you planning something in chrome? i just saw beautiful pics in retrogamer1990`s thread with the chrome backplate for a 5850... maybe you get some ideas there...
I like the non-WC'd backplates as well. Also like that you used as few 45's and 90's as possible. I always like the look of well planned and executed tube routing! :up:
http://www.abload.de/thumb/dscf0003wsxd.jpg http://www.abload.de/thumb/dscf00447pib.jpg http://www.abload.de/thumb/dscf0045ssys.jpg http://www.abload.de/thumb/dscf00460tut.jpg http://www.abload.de/thumb/dscf00472r6w.jpg http://www.abload.de/thumb/dscf0048yq81.jpg http://www.abload.de/thumb/dscf0050opvg.jpg http://www.abload.de/thumb/dscf0051ish4.jpg http://www.abload.de/thumb/dscf0052cpu2.jpg
http://www.abload.de/thumb/dscf00535tmn.jpg http://www.abload.de/thumb/dscf0054kp77.jpg http://www.abload.de/thumb/dscf00559st8.jpg http://www.abload.de/thumb/dscf0056es6u.jpg http://www.abload.de/thumb/dscf0062qo9a.jpg http://www.abload.de/thumb/dscf0063nsos.jpg http://www.abload.de/thumb/dscf0064ttpo.jpg http://www.abload.de/thumb/dscf0065csag.jpg
Nice wallpapers.
I have few questions for you, hope you don't mind.
How do you find asus rampage II extreme motherboard? I was planning to wait for rampage III extreme or buy evga x58 classified. What do you recommend?
Where could I find good color coolant without uv properties? I heard colour coolant leaves the residue on the waterblock. Did you have this problem in your watercooling setup?
nice shots ;) how did you make the water blue when you took a grey picture?
really nice shots malik!! i guess colorkey ipuol... right?
hm work with photoshop but i do not know it. aaaah . If you can tell me the solution of that problem, i will contact you ;)
i don`t use photoshop at all... i am a noob when it comes to image processing... :rolleyes:
I think now you can wait for new rampage extreme or evga classfield.
About coolant - i don't have any problems with the residue on the waterblock. I use only F1 liquids and for now everything is ok :)
Heh, when i want make some "artistic" photos i use adobe, corel and ... acdsee ;) Contact me if you want more ... :D
