hello,
i have a p6t dlx v1 flashed with 0006 bios
and i don't understand why i have turbo throttle with x21
C1E / speedstepp/TM fct were disable in the bios
any idea ?
hello,
any idea ?
damsxx: Post some pics and some more info. Try enabling EIST / Speedstep. How much can you overclock before the multi starts to drop from 21.0 at full load?
If your multi drops below 21 at idle, that is not turbo throttling. Adjust the Minimum processor state to 100% in the Control Panel -> Power Options to disable that feature.
What does CPU-Z show for bios version number in case your flash didn't go well?
i resolve my problem when i flash with 0007 version :D
I allmost hit the 5 ghz mark today:D
http://valid.canardpc.com/show_oc.php?id=691388
The cpu is cooled by a stock Vapochill LS.
When attempting to pulling my computer apart, The plastic 3 pin "thing" retention clip broke off on the 3 pin fan attachment to the motherboard. the fan attachment is on now, but barely. it will fall off with any movement. do i need to fix this and if so, how? can i just pull that plastic bing bing off and replace it????
Its chassis # 3
Overclocking on the Asus P6T Deluxe is so easy.
W3540 5 ghz:D
http://valid.canardpc.com/show_oc.php?id=692548
Oh man. I had been wishing I'd find something like this bios for a while. Can we get someone to consolidate the important info such as the bios file links, the cross-flashing instructions, and model compatibility into a sticky. I'm sure there's gotta be thousands of people who could benefit from this but its hidden away impossible to find. I didn't know it existed until someone mentioned it in another thread on a different forum. I had assumed any bios would simply be released on asus's website :mad:. I had also been kicking myself because I would've bought a gigabyte or dfi board instead if I'd known about this problem before hand but now it's all good.
I had been running at 20x200 1.2625v 8hr p95 blend stable,now I can run 21x200 1.3v 1.5hr prime stable and counting. :clap:
So far loving my P6T Deluxe (1504)
I got a i7 920 D0 brilliant batch 3845B260 I heared it gets you around 4.8ghz+ on water. :eek:
My max stable BCLK findings on Air so far is 230 BCLK.... not a bad mobo afterall....
http://img98.imageshack.us/img98/638/230bclk.jpg
When and if I get water cooling I will certainly push it beyound 4.8 ghz should do within 1.5v but till then im happy with that speed and temp, as its inside the case and max temp always stays within 78-80 after priming. :rolleyes:
4200MHz @ 1.22v (prime stable) 24/7 Settings
http://img401.imageshack.us/img401/193/69453143.jpg
GTA Crysiss cant even use the full power of the CPU its kinda overkill! Heavy couple hours of gaming temp never exceeds 72c NEVER! :yepp:
One funny thing I have noticed it doesnt show 208 BCLK on CPUZ even when on bios its 208 BCLK CPUZ shows 206.8 BCLK, dont know why (enlight me if you can) and any more BCLK after that requires significant voltage increase! :confused:
_____________________________________________
4.2GHz HT @ 1.22v
ASUS P6T DELUXE
Megahalems
GTX 285 OC
6GB CORSAIR
64GB OCZ SSD
CORSAIR TX 650
My (mediocre):D result on P6TD DLX
dailly :
http://img185.imageshack.us/i/91234479.jpg/
http://img185.imageshack.us/img185/448/91234479.th.jpg
bench (only) test: (still NO turbo throttling)
http://img42.imageshack.us/i/99657749.jpg/
http://img42.imageshack.us/img42/760/99657749.th.jpg
my CONCERN is :
bios 0106 (P6TD DLX) DO have turbo throttling problem (4.21ghz and beyond)....i have tested @4.3ghz (1.28v vcore&vqpi)...after a while (bencmarking) it will trottling down to 20x.
(sorry no screenshot, it's gone..overwriten! damn!)
STILL WAITING FOR (FORBIDEN :D) SPECIAL BIOS FOR P6TD DELUXE :clap:
I need help!!!
I'm hitting a wall with Bclk with the 0006 bios. Everything on theboard is set to auto apart from vcore and vdimm. what settings (increases in voltage) would help me get past this (i think this is mobo related as i have another chip that hits the wall at the same point)
Ahem....
whats your max stable BCLK? :D
Guys what's the best tool for oc'ing from windows? i've been trying turbov but that thing crashes the system all the time even on stable settings... i have the P6T vanilla running win7 btw.
1)I've already tried running my ram at well below spec's (about 1200) when trying to find my max. Also did the same for the cpu multi (is there a best one to pick? was using 15)
2)have been bumping the PLL, should i be increasing the VQPI instead?(still running stock air, just doing some tests to find the limit of the system)
3)I'm stuck at 215, 220 will not boot at all :down:
P6T v2 bios 0610
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...XE-V2-0610.zip
:D:D:D
PCIeX freq @110mhz :shocked: - 120mhz :shocked:.
:D:D:D
it's must've been a typo? right?
cmiiw mr watcher :ROTF:
update: it's confirmed (by phone) :hammer:
... what mr watcher means is indeed 110mhz-120mhz (earlier i think 101-102 :rofl:)
:slapass:
and ALSO.....
i would like to clarify my earlier statement that bios 0106 have turbo throttling problem...it seems my "old" turbo software is the culprit here and my big mouth too...:rofl:
@4.27ghz and still no turbo throttling, a
http://img33.imageshack.us/img33/5130/bechonly.th.jpg
at above screenshot i am using latest "real temp beta package" that unclewebb gave to me.. (thanks uncle :clap::up:)...
sorry for the inconvenience
ps : maybe someone like to try it at 4.5ghz and beyond just to make sure of it....i cannot do it,,,,regarding my HSF and my skill :D
from asus website
[ 0610 ]
Fixed Dell Multimedia keyboard or Logitech G15 would not be detected at POST
