Which went bad CPU or MB?
Hey guys, I've recently had problems with my OC on my new I7 computer that I got in December. It was stable @ 4GHz now it's not even at the default I7 920 speed of 2.6GHz. I have everything currently in its default settings.
I'm not within my 30 day return window from newegg.com so I'm assuming I'd have to get a hold of the manufacture. So my question for you guys is what's the most likely problem the CPU or the MB?
Usually my "instability" occurs while I run my Seti@Home 24/7, then at some time I'll come back to the computer and thinking the monitor has shut off from "power savings" it really has just "froze". (Only monitor is setup for "sleep" everything else runs 24/7) I can tell from my little LCD poster as to the temp of the CPU, if its in the 30's *C range or more like 45-55*C.
SOOOoo...... what do you guys think? CPU or MB? or need more details?
Oh yeah..... my 1000W PSU will be here today. I'll reformat and reinstall Vista 64 after that.
Jason
