'By setting the Transaction Booster to Disabled, and A relax level of 0, I was able to successfully Prime with a tad lower CPU core voltages.'
This shouldn't be correct. Lowering tRD (PL) as in your case results in lowering NB voltages for same fsb.
I just want to share my stable settings with others as well. Using D9's and these are rock solid. Still, I'm going to try and lower some of these voltages so please take a look and see which ones you think I "should" be able to lower most likely. The vcore could be one as I just carried over that voltage from my P5K Premium.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2- 800
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 10
RAS# to RAS# Delay : 2
Row Refresh Cycle Time : 25
Write Recovery Time : 3
Read to Precharge Time : 3
Read to Write Delay (S/D) : 7
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: DISABLED
Ai Clock Twister : STRONG
Transaction Booster : DISABLED
Boost Level : 0
CPU Voltage : 1.4375 (Actual 1.41)
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.49
DRAM Voltage : 2.04
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
Loadline Calibration : ENABLED
CPU GTL Reference : .63x
North Bridge GTL Reference : .67x
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
Anyone running Vista and have tried the RTM service pack?
looking for comments b4 I load it, M$ Tech Net has very little feedback atm
I'm having trouble getting my memory to post.
I am trying 8x500 for and even 4.0. With all the memory settings on auto it boots up and passes Orthos Small FFT (16 hours) and Large FFT (7.5 hours)
But when I try to set the memory timings manually, it hangs at DET DRAM
When I run it with a 400 FSB it posts at 5-5-5-12 no problem. But at 1:1 with 500 FSB it only works on AUTO.:shrug:
Extreme Tweaker
- Ratio CMOS Setting : 8
FSB Frequency : 500
PCI-E Frequency: 120
DRAM Frequency: DDR2- 1000
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 18
(I had all of these settings manual on my Q6600, but haven't got there yet since installing the E8400)
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
DRAM Static Read Control: AUTO (Have tried with this on and still nothing)
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : 1.36875
CPU PLL Voltage : AUTO
North Bridge Voltage : 1.61
DRAM Voltage : 2.04
FSB Termination Voltage : 1.52
South Bridge Voltage : AUTO
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
- Ratio CMOS Setting : 8.0
USB Configuration
I have mojr issue with 400mhz strap...333 works fine tho. Includes graphical errors, usb drops, network issue...pretty much guarantees it's nothing but a chipset/bios issue.
Can somebody tell me, what "CPU TM Function" does and if it should be enabled or disabled?
I took a look at my manual, at wikipedia.org and searched over google but I didn`t find any explanation :(
And is "Vanderpool" only useful when using system or does it do anything else (with normal desktop system for gaming, surfing and things like that for example)?
Thank you in advance for your help :)
I would honestly tell people to make sure they remount their N/S Bridge HS with AS5. I have found 2 board where the TC wasn't making full contact on the IHS of the N/S Bridge IHS. Maybe that was just me and my boards. Here are pics right here:
http://i11.photobucket.com/albums/a1...h_4658f9e0.jpg
http://i11.photobucket.com/albums/a1...h_cbf00ab5.jpg
http://i11.photobucket.com/albums/a1...h_8be3f661.jpg
http://i11.photobucket.com/albums/a1...h_19d81b59.jpg
But in a nutshell it's a good idea to remove the oem TC and use AS5 and place the HS back on to be assured that the HS is making full contact with the IHS of the N/S Bridge IHS.
I think I finally figured this board out. 460fsb stable and the memory is holding it's own, too. I think the mix of Transaction Booster disabled (0) , Statis Read disabled and Clock twister strong did it for me. I wasn't really having trouble getting hte higher memory frequencies stable, but I was loosing a lot of performance from slackened board timings.
Does it seem like my board voltages are a little high for a dual-core? I'm going to try to lower them a bit and see what happens.
ps. don't laugh at my vCore. :eek: I wish it didn't take that much, but it does.
I reinstalled my Windows and first saved my OC Profile and then loaded setup defaults and now I'm getting that CPU Fan error! Press F1 to Resume. How do I get rid of that error.
What did you use to read all that info out ?
EDIT:
Can the people with 445+ FSB on Q6600 give me this info :
FSB x MP
PLL : .... V
NB : .... V
FSB : .... V
SB : .... V
CPU GTL : ....
NB GTL : ....
SB 1.5V : .... V
NB Strap : .... (200/266/333/400)
AI Clock Twister : ....
Transaction Booster : ...
According to my math, I need to be using TRD 9 for 450x8 with cas latency 5 according to that Anandtech article. That sound about right?
Grnfinger, I'd be delighted to try it for you if I could find it. I'm only running refresh 1.
I got a new E8400 last night, and it's a world of difference. If anyone cares to share their opinions, it would be appreciated. THREAD LINK.
People I got a problem.
I was able to run 468 x 9 with a older BIOS. Now I'm only able to run 445 x 9, this is Prime95 stable for 5 minutes...
In the BIOS I set everything on AUTO except the Vcore.
With these settings Prime95 is only stable for 8 hours and more on 425 x 9...
When I try 468 x 9 it freezes just before I go into Vista.
Surely a problem with the voltage somewhere. But I don't know all these settings because I come frome a P35-DQ6...
Now I tried to find the max stable FSB with all voltages set to AUTO and this was 470 x 7, when I try 475 x 7 it fails within 5 min at Prime95.
So normally I should be able to get 470 x 9 with everything on AUTO BUT (!) it doesn't like I explained earlier...
Some help is much appreciated !!!
(Somebody now a program wich can read PLL/NB/SB voltage in windows ?)
