Which pot are you turning, i've had between myself and customers computers probably 25 fortrons, and i usually tweak them all. I've never seen the 3.3 adjustment changing anything but.
Go through this thread started by a hell of a good guy and it will let you know everything there is about a fortron 530
http://www.xtremesystems.org/forums/...hlight=fortron
I think after that thread here, and OCforums. 2 weeks later after everyone started snatching the fortrons up from newegg and such, and Newegg was even running out of stock on them. Everyplace raised the price on the $10 at least. Supply and demand and so on!!!!!
Everyone know's im a fortron fanboy. I had to use my fortron 530 in a dual Xeon rig i sold to a customer last week, i have another one on the way, But until them in my around 3ghz A64 rig, Im actually using a never had the side off the fortron "STOCK" AURORA 350watt fortron.
Pics, Dont laugh at the hacked up case. It's better than proping it up on it's side, I order the Vapo LS on Wednesday and it got here Friday, Fast ass Ground shippping. I also ordered a Lian LI PC65 case to go with it and it didnt come as fast as the LS did!!! But im going to try a few cases i have here.
So i doubt there's one of you that would let a Vapo LS sit idle and im doing a lot of MB testing this weekend. So i cut up a cheap Micro Case for easy Access and bolted it down to the Vapo LS.
Here's some pics using only a 350watt Fortron with no pot adjustment. 290 HTT 1:1 memory!! Im using Crucial 3200 Ballistix memory So i dont need to adjust the memory over 3volts. I do have a OCZ booster but it's not needed, I have the 4v bios on my DFI. Also in the pics is a Pic with a Red arrow pointing @ the 350watt Fortron, and a 3ghz screenie. I can Light bench, Sisoft or a small super pi, But no 3dmark and such. And ugly case pics.
Im surprised this Vapo LS hits -60 unloaded and it's a Revision 1 LS. not a Revision 2 that's supposed to get colder.
