Yes to enabled or disabled?
I have it enabled
i enabled memory remap and all is good now. Thanks. I will be bugging the snot out of yall the next few days though, until i learn enough to start contributing. Sooooo many settings its overwhelming. This is way different than the nforce i've been using the past 3+ years. I have my q9650 at 4400mhz atm on mostly auto settings, only 100mhz shy of my goal but memory benchmarks are poor. I'll post my settings in a few for some suggestions. Oh and thanks again!!
PLL was the key to success, 2 notches and a little vcore and she primed all night :up:
Now for the ram , still not totally tweaked but more than accpetable for the first run.
http://i237.photobucket.com/albums/f.../40_gskill.png
http://i237.photobucket.com/albums/f...finger/20k.jpg
Ok this is where i'm stable so far. Well i cant really call it stable cos ive only been running it an hour, but i've had no issues at theses settings. vcore could probably come down, this was my starting point. I'm still reading this thread. Made it to page 15 so far. What should i adjust next? Thanks!
http://img391.imageshack.us/img391/4...tureoo8.th.jpghttp://img391.imageshack.us/images/thpix.gif
Temps are too high for me. What voltages & temps were 4GHZ. I'm sure you curious to see how high it will go but after your done drop down to 4Ghz anything over that just seems like overkill for casual day to day use. You can alway crank it up when u bench or game.
I actually thought the temps were bearable coming from dual cores with similar temps at similar clocks/volts. I'll drop vcore and see what happens. I'm idling 35-40c. 78F ambient.
@cryptik, check this out . all i did was disable LLC and set 1.4vcore in bios,changed fsb from 445 to 456 and its sill priming fine. before i couldnt get prime any higher than 4050.http://i436.photobucket.com/albums/q...cs/4100135.jpg
someone can tell me if those 2x2gb ddr2 kit are good for the asus maximus 2 formula?
teamgroup extreme dark series pc2 8500 1066 mhz 5-5-5 15 2x2gb
g.skill f2-8500cl5d-4gbpk 2x2gb
thanjs
I have just bought a p5q deluxe and I had trouble even loading vista at stock settings with my q9450. I have been told to downgrade bios and that the new bioses were problematic. This gave me a bad taste on my first day.
Is maximus 2 formula a better overclocker than the p5q deluxe? Do the bioses have less quirks? At least the layout seems to be better. I can keep my sound card on the bottom slot away from my video card.
No, I have seen other people having problems on the p5q thread with the same combo. All my components were working on another motherboard. Everything is at stock, I tried with one dimm, also increased ram voltage. Memory is micron d9gkx.
why do you say p5q-d is a better performer? higher max fsb? higher cpu or ram overclock?
For me Grnfinger, the best 1066 2x2 sticks were, hands down, the Corsair Dominators.
1147 on 478 FSB with an E8400 PL7
1122 on 421 FSB with a QX9650 PL6
Great RAM. :up:
Set PLL at 1.56 actual and chip stabilized after that.
Now its getting the ram tweaked out at 1130MHz, GSkills should be able to do it.
I have a 2x1GB kit of them I might grab a 2x2GB kit this weekend. Really want 1130MHz for ram.
These ones loved my Maximus.
