Originally Posted by
continuum
Just got a G0, L726A from ClubIT.
Running an old school Asus P5B Deluxe WiFiAP BIOS 1215, Thermalright Ultra-120 Extreme w/Nexus 120mm, a dime under the bracket...
POSTs at 3.2ghz (8*400mhz) and 1.350v but doesn't even get to the Windows load screen, self reboots. At 1.3625v it makes it to the Windows load screen and reboots. At 1.3750v it makes it almost fully to the Windows desktop and then reboots. VID is 1.3250v.
Backed it down to 1.3250v and 2.8ghz for now, if it survives Orthos by tomorrow afternoon (~18 hours away) I'll see if that helps the AS5 set and if I can crank it a little harder. Disappointed so far.
I've got two other Q6600's here... one is a G0, L724A from the tankguys preorder. Did 3.2ghz (8*400mhz) at 1.3625v just fine, but at 1.350v core 2 consistently failed Orthos between 4 and 8 hours. Handles 48hr+ of Orthos with a 3D program just fine tho. Booted right up at 1.350v tho. VID is 1.2750v.
The other is a B3 from Fry's 4th of July sale... L644G, booted up just fine at default voltage (I forget what, 1.325v-ish?) at 3.2ghz (8*400mhz) and was rock solid for 48hr+ of Orthos with a 3D program running as well...
Will probably end up keeping the B3 and selling both G0's for a slight loss from the way it looks.
