x 2 :yepp:
Hehe I will list that all...need some time ;)
@ bruce
Why should I keep all that cpus ? Useless for me only the destroyed cpus ( 16 of them ) will be mine forever :D
hehe lol, some crazy stuff in here. :D
i bought my last cpu before 2 months....
Got anything that does => 3GHz prime stable on stock air with ambient temp at +-25C? :D
@ gianni
Whats up with you ? Why dont you buy any cpus right now ?
i'm planing to buy some hardcore homecinema stuff :D
:shocked: TRAITOR!!:rofl:
hehe...
nice signature btw :)
Thanks man, which part do you like?
"the overclocking world record data base" :D
A recent addition :D The colours go so nicely with my avvie :D
Just won this one:
AMD ENG SAMPLE
1SP2400GK0603
FCBDF 0534VPAW
FA34774150046
Hehe, shame I don't have a mobo for it:p:
However, I DO soon have a mobo for this 4000+:
KAB1E 0626FPMW
1489588F60017
Same batch as the WR chip, but lower batch #.
0626FPMW mania lol:D
Oh yes, I've also got a question. Athlon64s are 1.4v, right? Why does everything report my 3700+ as 1.328v/1.33v when I set the voltage to Auto? And are there any utilities to change vcc/vdimm in Windows? I'm at a few plateaus (see sig) and can't break them because higher voltages at any frequency prevent Windows from booting :\
The san diegos in the older generation had 1.4 volts as default and later it came to 1.392 v, 1.376 v, 1.360 v, 1.344 v and the lastest had 1.312 volts as default. All read out with CPU-Z.
The VID said 1.40, 1.375, 1.35 ;)
So I should check the VID with CoreTemp?
Hmm, seems I've got a 1.35v chip...
Is there anything I could use?Quote:
a better cooling :D (my answer to everything) :D
cpuz reports 1,296v (actually in bios I set 1,3x104%)
yeah I heard some guys with my stepping could do 3,1 Ghz with stock voltages, maybe mine too but I cannot test
my # :
OSA185DAA6CD
LCBQE 0730DPMW
load temps are 52/54 IIRC, my air cooling may not be the best, it's Noctua UH9F + 2x92mm fans in push pull
the weird part is that it's OCCT stable at 1,28v @ 3 Ghz but crashes in Orthos after ~2 hours, 1,3 is 24h+ Orthos stable
. AMD 64 X2 6400+
. Sapphire AM2-RD790FX
. OCZ 2GB PC6400 Ram 5-5-5-15-2T
. Sapphire ATI HD3870
. Vapochill LS İşlemci soğutma -45C
4000mhz 1m:D
http://www.hardwarena.com/images/sto...6400-4000_.jpg
^^ now we waiting for new WR on AMD ... try to break 4263.65 :D
