Cant u reroll back to 10.12 WHQL or 10.5? They seem like the most reliable ati drivers..
norton has been running seamlessly since i built this setup likw 15months ago. recently however ive been having graphics and ati driver issues. 10-10 wont run. 10-11 doesnt work correctly after install, but still works and every other night, the gpu crashes my pc b/c CCC kept the clocks too hight and 10-11 wouldnt let me in to tone it down
norton found it when i downloaded the driver. it updates everyday. no other virus scanner or spyware scanner can run seamlessy in win 7 64bit. the ones i try keep crashing my system so i dont run them unless i doubt norton and have no reason too
I'm running 6850 Crossfire here, is anybody having crashing issues with Bad Company 2? It ran perfectly fine on my GTX 480 setup.
Microsoft Security Essentials is more seemliness & its seems that Norton is making a false positive & is trying to block that DLL & ATI needs it active to function properly.
So if you download it from AMD & not from the leaked links then its safe & your Norton is in error for whatever reason.
if its blocking the dll it needs, then why does ati need ultradefragger to run hydravision?
11.1a installed fine no issues
leads me back to believe 11.1, but w/e i got a working driver
I installed 11.1a.
I opened up CCC and enabled CrossfireX for my 4850x2 and its not running both cores. MW@H is only running on 1 core even though crossfire is enabled. anyone else with a dual core chip having this same issue?
Yes I had a similar issue with an older Catalyst when I first got my UD5, thought one of my 3870X2's had lost a core so went & got a 6950. New 6950 artifacted at stock so I sent it back & after a fresh install of 7 64-Bit, the latest GB bios & install of 11.1a all 4 cores run fine..... dont know what I did but it now works!
Adaptive Multi sample AA can coarse flickering in BFBC2.
Guys sorry to be a bit lame & not go look for myself but how do these numbers stack up? anyone running a similar setup?
http://i106.photobucket.com/albums/m...k069501475.png
Give vantage a run and i'll compare at the same (GPU) clocks :) I only get about 27k in 06, due to it obviously being cpu freq limited. But result is spot on from the looks of it :up:
C-N seems about right for a 6970..
i contacted AMD about the issues i was having: the crashing and also the fact that CrossfireX was not enabling the use of both cores on my GPU and they said they are investigating and will fix it with a driver update
I'm going back to Cat 10.12. This version has Edge Detect AA missing. WTF?
