actually newegg is doing some other nice bundles like the Corsair HX1000 deal where the board works out around US$500 :up:
Here they all are
http://www.newegg.com/Product/Produc...Size=10&page=1
Here they all are
i compiled a bunch of cracker deals :D
There are lots of great deals I see on Newegg for UD9 :up:
If you don't want to pay US$700 for the board alone you can pick up some nice bundles that would make it cost $500 in most instances if you get some nice RAM from OCZ or PSU from Corsair etc
check out all the bundles here
http://www.newegg.com/Product/Produc...Size=10&Page=1
Here are some awesome bundles IMO:
$774.98 :shocked: (that would make UD9 only $475 :up:)
http://www.newegg.com/Product/ComboD...t=Combo.435335
GIGABYTE GA-X58A-UD9 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 XL ATX Intel Motherboard
LIAN LI PC-P80 Black Aluminum ATX Full Tower Computer Case
$1479.99 (UD9 works out at $480)
http://www.newegg.com/Product/ComboD...t=Combo.437350
Intel Core i7-980X Extreme Edition Gulftown 3.33GHz LGA 1366 130W Six-Core Desktop Processor BX80613I7980X
$779.99 (UD9 works out at $490)
http://www.newegg.com/Product/ComboD...t=Combo.437331
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor BX80601930
$734.98 (UD9 works out at $505 or $495 after rebate)
http://www.newegg.com/Product/ComboD...t=Combo.435343
CORSAIR HX Series CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active ...
$694.98 (UD9 works out at $510)
http://www.newegg.com/Product/ComboD...t=Combo.449191
OCZ Reaper HPC 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model OCZ3RPR2000LV6GK
$619.98 :shocked: (UD9 works out at $514 or $494 after rebate)
http://www.newegg.com/Product/ComboD...t=Combo.435340
Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC ...
Rosty from OCTeamDenmark did a little house cleaning and washed the UD9:D
http://www.youtube.com/watch?v=huGl2...layer_embedded
Yeah its Ultra Durable allright:ROTF:
I love this board!! Got it basically the same day it was available. Only problem is I cant get into windows anymore.. The board just shuts off. I'm on f3. Tried 3 power sources. Tried 3 cpu's.
Different kit of memory.. The last thing I noticed before taking a break from the frustration was that depending on what hard drive I plugged in ( say my os hd ) the board would shut off right away with that one..
I'm having similar issues with several biosses for all diferrent boards on the GB lineup...Try a reflash back to F2 mate or even F4 series... F4B works nicely here for the review...
Thanks so much man! :) I'll give that a go. I used an older os to flash the bios the first time. I'll try q-flash and see. I thought maybe the nb was getting hot so I decided to install some water cooling. I felt the back of the board after that and everything seemed great.. No heat at all so I dont think that's it.. Especially since I can sit in the bios for a long time and it never shuts down.. only during os startup..
F4B is okay, needs an AHCI hold time inserted for booting optical SATA drives, though.
Just updated the bios.. Same issue.. This time I booted into windows.. then ran 3dmark 06 cpu test at 4ghz.. The board powered off right away.. :( bummer.. Hopefully it's not broken for some reason.. Barely used it.
Before I rma the ud9 does anyone have any insight on why it shuts off during cpu tests and then on windows startup.. :) Thanks so much for any help in advance
even at stock?
At stock it will make it through the vantage stress test using a 980x that's brand new.. On water it reaches 40c
At 4ghz however, the mobo just shuts off.. That's a pretty moderate clock for water cooling as well.. I dont get it. Thanks so much!!
@Raju The ioh is water cooled so that does'nt get hot at all..
pull it all off and put the stock HS on the board(the big UD9 heatsink i mean) and try again please
Thanks Dinos! Will do that now. cheers! -Beaux
So I did what you said Dinos.. I put on the large one.. Still shuts off at 4ghz cpu test.. Been running for hours now though at stock.. Dont get it :(
have you tried the latest bios
if that doesnt work RMA it hard to say what it is tbh...odd one for sure
Check with another power supply?
I had a smiliar problem where my board (gigabyte x58 Extreme tho) just shut off and then i figure out it was my Chieftech PSU that had a wierd 24 pin so if i touched it my comp just turned of.
Tho it got worse after a while since i didnt notice anything at the start.
Man, SO it looks like there was some grease or something in the cpu socket.. All the pins are fine but when I turned the board to the side I could see something wet or weird on the pins.. I noticed that after the board powers off, when I take the cpu out it has some grease or it's a little wet.. I took some electrosolve and cleaned it all off and then dried it.. Just put the cpu back in and we'll see if there are any traces left.. It looked really clean and nice though after I did that so fingers crossed!! :D
Thank you for helpful advise, dinos22 & stasio!!:D
I will test your new BIOS "F4f" under LN2 a.s.a.p.
My board was broken.. Did'nt even use it hardly at all.. looked brand new when it broke.. Was hoping for an x5677 run with that board but I'll have to wait til it gets back from RMA.. I just dont think the rampage lll has what it takes to get the wprime/xeon numbers.. I overclocked the x5677 to 6169mhz on the rampage and ran wprime 32m and still only ranked 3rd for the quad cores.. something is weird with that board and xeons. cant wait for the UD9! :D
I face very strange behavior when I run 3D06.
My UD9 3D06 score are not very stable.
CPU(980X) & GPU(GTX480) clock are all default.
1st run, I get around 23k marks.
2nd run, I get around 22.7k marks.
3rd run, I get around 22.5k marks.
The score going down around 200 - 300 score every run.
If I close 3D06, The score go back around 23k.
But same problems happens if I never close 3D06.
I checked score details, CPU Score isi very stable.
It around 7650 - 7750.
But GT2 & HDR1 score is very ramdom.
These test score go down around 5 - 15 fps.
Other mobo does not happen these kind of score falls.
I had already change PCI-E slots & OS/Driver.
Is this UD9 character or defect roducts?
Please give me some suggestions?
(Sorry for my bad english)
