HMmm I dont see a big difference. Only 300 points in the X-CPU bench. Thus it is the multicore bench, but we are talking here about the single-thread performance.
Furthermore, the used RAMs for the X6 system are quite good:
@informal:Quote:
System specs:
CPU: AMD Phenom II X6 1055T
MB: MSI-790FX-GD70 Bios v1.10b8
RAM: Corsair CMD8GX3M4A 1600 C8 at 1333-9-9-9-24 (all auto)
GPU: 4770 CF stock clocks
PSU: Corsair HX850
Yes, saw that problem with the NB clocks, but as stated above, the andandtech results are still better, and these are not oc'ed.
@jcmarfilph:
Hmm ok C&Q ... could be a problem, indeed.
@informal (again ;-)
Was C&Q enabled at your run @3.2 GHz ? If yes could you try once with disabled C&Q ?
thx
Opteron146
