If by listening you mean...
Originally Posted by
ultralo1
Why ask, you have not listened to anything that you have been told so far.
I should stop what I'm doing and not consider anything other than what I'm told to do...
Yeah, I'm not listening!
I willingly and graciously accept the choice of any person to stop following this thread.
Otherwise, I'm going to have way too much fun watching all of the complaints that keep streaming in.
That alone is worth you're sticking around!
Shingoshi
Laying my cards on the table...
Or more precisely, laying more boards out to make my case!
http://img514.imageshack.us/img514/3512/dsc00020f.jpg
I simply don't have the option to build something SIMPLE. It never was my intent to do so, and NEVER will be. As is evident, I already have the boards for this project. They need a home, and I have to build one. It's kind of like all of you telling me to move into a single room house, with FOUR kids!!
These are my FOUR Tyan S2912 motherboards. Each measuring 13"x12". They hold two processors each with 4 DIMM slots/processor. I have laid them out in the manner they will be assembled. Overlapping them as I have done here will allow me access to all processors for mounting my cooling blocks, while still being able to mount them in less than a 1U space in the top of the case. With all of my inexperience, it seems I'm doing just fine with the details of this project.
So if you're too impatient, too short-sighted and too unimaginative to comprehend why this project was undertaken, and that it's NOT going to change, I STRONGLY SUGGEST YOU SEEK COUNSELING, ELSEWHERE!!
Shingoshi
What if anything has changed in the meantime?
n00b 0f l337
I'm pretty sure Jinu can attest to Cryo-tek's truthiness. Your posting in the same way that anyone could go "I count all of wd's post as bullsh** as I've never seen him post a picture or truly answer questions as direct as I'd like to see them directly posted."
As far as regassing a polycold, the unit DID NOT have a polycold mix of gases in it upon receiving.
wdrzal
sometime you can be made to beleive what is not true,because you your self don't know the truth.
I never posted a picture because I never built a rig to phase cool cpu's yet.
you don't have to beleive what I say either ,I can't force anyone.
I admit I haven't read the rest of this thread yet (EDIT: I have now). But I'm just curious if you've built a phase-change system since you posted this about three years ago?
For the record, I'm not cryo-tech. I will post pictures at every stage of my build, and they won't be blurry. EDIT: They will be as sharp as my Sony DSC-P32 allows. I will provide proof of everything I have accomplished. And whatever knowledge I don't have now, will be gathered as I proceed through my build. I will have the time to learn everything that I need to know. Especially as I'm now reading through the old posts here and elsewhere.
And since no one here actually knew this, let me be perfectly clear. I am a trained welder, arc welding and brazing included. In fact, I was a metal sculptor, any very meticulous. So your concerns for my lack of ability is completely unjustified. Just so you know...
Shingoshi
EDIT: The process of cooling the heated outlet refrigerant from my two-stage vortex tubes will probably be the greatest load in the system. And that load will be stable during the entire time that the system is running. Providing enough evaporation to condense my coldest refrigerant will be the system's first goal. Cooling my processors will essentially be incidental to the actual running of the system. So for the most part, cooling of my processors will be a by-product of the operational system. Meaning I will concentrate on condensing my lowest temperature refrigerant, and cooling my processors secondarily. This is specifically why I'm concentrating on building the refrigeration system as my highest priority.
EDIT: There is one major concern that I have in running a 24/7 server. And that concern is that the system can still operate, even at a diminished capacity if any one component fails. That's the major benefit of having four parallel compressors in my first-stage. If one of them fails, I have three more to fall back on. If the second-stage goes down, it won't be as much of an issue as the first-stage.
I was wondering how long it would take...
SexyMF
This has turned rather sad. It is a sad reflection on almost all posters. You don't look good by bagging somebody else. They may be way off the mark but most of the comments now are just snide remarks made without even constructive criticism.
Yes it (not being quite sure of what it exatly will be) is grand - but just let the guy have a go at it.
In terms of a simple comment Shingoshi, you will need better grade tubing and reserviors to cope with low temp working liquid.
Frankly, I've found the constant attack(s) to be nothing more than I sign of gross immaturity. And as with all children, I simply choose to ignore nonsense like this. That having been said, I really wish to thank you for the recognition of this.
Shingoshi
Back to the issue of turboexpanders...
Last night I went to bed thinking about this issue from another point of view. What's required for a turboexpander to work in a situation like this is predominantly it's size. I had initially investigated the use of small turbochargers for motorcycles having a displacement of 500cc. But I quickly realized the amount of flow through them would simply be too great for any system of this size. So then I thought about my old hobby, radio controlled aircraft. It dawned on me that if turbochargers existed for them, they would be properly suited for this project. So now I submit to all of you the following:
1.) RC turbo charger
2.) http://image2-4.rcuniverse.com/e1/fo...10/Su35824.jpg
3.) How to Make Turbochargers for Nitro Powered RC Cars
Now that we've seen what one would look like, those of you who have the means (metal working materials) should now focus on how to produce one, instead of the constant rants about why this is impossible or implausible. Simply put, start being productive contributors to a working solution, instead of only wanting to detract from one.
Shingoshi
