yeah have tryed lowering it cant get prime 95 stable any lower not sure how i can lower vcore and still keep it stable what else can i tweak any suggestions ?
Above 450 with a 7 multi with a 1:1 ratio
My dominator 1066 @ 900 something, and 666 18
First I did a medium data test with occt and as soon as the first minute was over it would lock up, doing a small data set test would last 5 mins before it would lock up.
Thats when i decided to set everything to its normal settings (except C1E ect) and do a small data test.
Ive completed a second pass of occt small data test and the same error occured. Would it sound right that its the cpu giving me problems. This cpu has been through a P5NT-deluxe and a X48-DQ6 (so its had all sorts of voltages pumped at it) with really unsuccessful OC results.
Obviously, your CPU is a dud for OC-ing. 3.2GHz is still a 25% OC, but it's kind of dissapointing for a G0. At least you know that you have tried everything that you could do. More luck next time. :)
I am so jealous. Good job!
I will have to do a few runs before I sell my golden Q6600. I will run some tests tomorrow and get some screenshots up.
It's irony. I was j/k.Quote:
Originally Posted by fatguy1992
NP, I wish I could help...
If you can get Q9550 that would be completely different story. 4GHz on air should be a piece of cake, unless your luck comes into play again. :DQuote:
Might consider getting another Q6600 or try a Q9550 and see how i go.
Oh thanks makes sense now :)
Also after my quick OC session I went to play some games and I accidentally set my Vcore to 1.2375v (BIOS) and OMG it worked :eek:
http://i292.photobucket.com/albums/m...zOMFGVcore.jpg
:clap: 1.24v @3.6GHz even if it is not P95 stable is very impressive. It should need 1.45v to be same stable @4GHz.
Its actually 1.2v for 3.6GHz (after vdrop) :D
Also It ran Prime 95 for a min. I could have run it longer, but I didn't feel like it.
Whats your vid on that chip arapab? I had my Q6600 set @ 1.42v 3.4 ghz stable everything on my ga-x38-dq6 but could push it to 3.6 ghz max on air w/out constant issues... ?? never went over 1.5v however??? for the same token I was hoping to get 4ghz stable on my q9650 and havent been able to get it over 3.95ghz stable on air but then again Im running 4 sticks of 2 gig ocz reaper 1066 and waiting on my maximus formula to be rma'd back to me before I start pushing again....
Managed to get 3.6 prime stable with as low volts as i could...
http://i148.photobucket.com/albums/s...7/stable-2.jpg
Not bad i'd say ! Trying to see what i could get @ 3.7 :D So far i'm 2 hours in @ 1.392v load.
Gona be getting a new motherboard soon, most probably a EP45T-UD3R !
Get a UD3P, don't get a T version, the DDR2 versions are as good or better then DDR3 and since u already have DDR2 it will save you some money ;)
I was thinkin the same until i came across an OCZ 2x2 12800 kit for £75 :D So i'll be getting that. Also, there isn't any real (overclocking) difference between the R and the P is there? I won't be using crossfire, dual lan, or ultra TPM.. Maybe a more updated BIOS, but soon enough the R will also have updated BIOS's.
I'm pretty sure that the R and P version overclock about the same.
Whats the safest Voltage to run 24/7?? i just put my q6600 under water and at 1.5v its fine at 4.05ghz but it wont hit 4.15 without somtehing like 1.608v under load :-/
EVGA 790i Ultra SLi, it does have bad vdroop :-/
