Regarding all this debate over copper vs. aluminum.. let me tell you from years of my fetish with customizing my own heatsinks... I've customized them in so many different creative (unique) ways that none of you guys have ever done that I've gotten so close to patenting a few of the designs.
In short words:
Copper fins are better for high-speed air flow.
Aluminum fins are better for low-speed air flow. (EDIT: cheaper and lighter, plus the difference from copper is not really noticeable)
I know for a fact that copper is more efficient at heat transfer as long as the air flow is fast enough. Say, if copper can transfer heat more quickly from the base to the heatpipes than aluminum, the copper fins might just as well transfer more quickly via HIGH air pressure/flow. Many of us only pay attention to the CFM of air flow, while overlooking another important aspect of the inch or mm-H20 (or Hg) of the air pressure. For example, Thermaltake's Volcano 12 fan (which is 80mm x 32mm and has only 3 blades -- http://www.thermaltake.com/product/C...il/A1745/a1745 http://www.thermaltake.com/product/C..._image/fan.jpg) exerts higher pressure than a similar 5-blade fan operating at the same RPM. It actually gives lower CFM than a 5-blade fan would, but the pressure more than makes up for it (given that the fan is 38mm thick rather than 25mm). The noise generated remains pretty much the same.
It is very important for the copper fins to remain as thin as possible and also as close together as possible, while being optimally soldered to the heatpipes. As long as the dust does not build up, it is what made Thermalright's XP-90c perform better than the larger XP-120, at 2000+rpm fan speeds.
Although aluminum fins do pretty well with heatpipes, copper is just better if you have at least a 2000+ rpm fan blowing directly on it. I do not know exactly what the threshold would have to be (airflow CFM and air pressure) in order for copper fins to be more efficient than aluminum, but let's just say 2000 rpm for most heatpipe heatsinks out there. Zalman's hugely popular CNPS9700 would be nowhere nearly as good if the fins were aluminum instead of copper. On that heatsink, aluminum fins would perform just as well as copper only if it came with a super-quiet fan (say, 1500 rpm max). For fan-less heatsinks, aluminum is a god-send!
