Originally Posted by
BenchZowner
You failed at failing man :D
That won't work at all, because of the built-in overheating protection.
You can't kill a modern CPU that way no matter what you try.
Enter the BIOS, set the highest possible values for Vcore/Vfsb/Vpll, save & exit.
Remove the heatsink and leave the CPU alone and power up the system.
In most cases it will just try to power on and will auto-shutdown in less than a second.
In other cases it may "post" for a sec or two and then shutdown.
No harm done, in any way.
Once again, I repeat, I'm trying to see the effects of various high voltages combined or not in real-life conditions.
