VTT 1.65v for 666 . But it s DDR2 board, maybe it s different with DDR3 version.
^^ Thanks man. I have both versions of extreme with me. That is a bit scary VTT.. but I think 610 is boring so will try to push :P
Hi all ! With Intel P45 chipset, i see almost need more CPU VTT n PLL voltage ! Is there problem of giga P45 mobo or Intel P45 chipset ???
Not more, only the right balance
any idea where to get new bioses, f3b ?
Ygpm :)
I also have some Problem with the DDR3 Extrem Board to reach high fsb . Under Cascade i only can do fsb 570 Mhz ??? Bios F3b i also tested with F2 but no luk .
Bootscreen i can do Fsb 640 but no change to go into Windows .
I hope to have no big probleme with this mobo and Kingston HyperX .
Just big FSB.
To all the people clinging to this "high VTT will kill your CPU (because i read a thread of a thread of a thread that someone i have heard of has killed a CPU and seems to believe it was VTT responsible", so far there have been absolutely zero reported dead CPU's from using these high VTT on these P45 boards so far. Food for thought.
Im not saying its not true, but with over 50hrs benching at these high VTT on P45 im not convinced
T_M is the only difference between the GA-EP45T-DS3R and GA-EP45T-Extreme the watercooled northbridge? Or does the EP45T-Extreme have better caps/etc
edit: Nevermind I can see just from looking at pics the DS3R has totally different socket area.
Ya ! Can anybody setting 1T option for memory ?? Or 3T ^_^ !
I only have 1 one option "2T" !
AFAIK the 1T setting hasnt been fixed yet, but i havent tried any BIOS higher than f3b yet...
i recieved the P45T-Extreme but i need going today , i test i think this week end :)
i'm sure to be putting that suggestion through :)
asking for bioses takes a long time. even longer to get here when we could get it ourselves.
There was nobody when the deliverer came home.
I hope find the P45T-Extreme this evening at my back.
But I've no good memory ,just Pc10666 gskill for test some FSB boot.
Normally , Pc14400 is in delivery.
Edit : @home :D
Edit 2: First boot 500Mhz ,jump to 611Mhz with Set FSB
full air cooling.
Strap 400Mhz
Ram 1:1 my Gskill :(
Vcore 1.25V
Vdimm 1.55V 9-9-9-25
Others on Auto.
Edit 3 : 665MHz of FSB & 650MHz SPi 1Mo
:up:
Why has the DDR3 Version no CPU Reference options in the bios,like EP45-DQ6 or EP45 Extreme?
it does, they're just hidden, hit ctrl - f1 from the main bios screen, then they'll appear :)
Are you sure?I know this option from older GB Boards but here nothing happens.
Thats what i can see,it looks like i can scroll more down but there is nothing.
Flashing one more time f3b and back to f2 but makes no difference.
http://www.abload.de/img/img_1933800x600uqc.jpg
I'll double check on my board tonight, pretty sure they show up
But why not here :(
Advanced clock control section is the closest you'll get atm
