Err... The fins cool the pipes. ;)
This thing uses an EM pump, right?
This is right around the corner,
http://eprim.org/category/cooling/
can't this be done with some kinda Oil ? (expamle canola oil) be much cheaper.
Talk about being ahead of there time, check out these links to the company that made that gallium liquid xeon loop on our tax dollars.
http://www.techpowerup.com/?3105
http://www.its.org/node/5319
Haha, Tardbus is already doing Liquid Gallium cooling here: http://www.xtremesystems.org/forums/...ad.php?t=99240
this isn't really a pump though. :/
"An electromagnetic pump has several advantages over typical mechanical pump designs. It contains no moving parts, shafts, seals, etc., emits no noise or vibration, has unlimited MTBF and suffers no performance degrading over time"
it's moving by heat.
No, that would be convection.
Neither does this use a traditional electromagnetic pump. Or at least, if it does it's lying about the 'moving parts' thing. a traditional electromagnetic pump manipulates a piston using a solenoid type em field. a typical em pump has a cycle of 50hz, which is why i say flow rates here could be incredible.
but for this application an actual EM pump in the traditional sense would be useles. An EM pump could be used in any fluid application, but the danamics lm10 happens to be moving liquid metal.
-SOLENOID-
Soviet Russia used liquid metals to transfer heat from their submarine nuclear reactors. It did not go so well. Hopefully these guys have learned from their mistakes.
PS: This comment was meant to be funny. If you do not have a background in Cold War Soviet Nuclear Reactor design then this joke has probably been lost on you. Use Google and learn.
Well, if you had a ferromagnetic coolant, you could pump it by alternating the field on a couple electromagnets. Much like a Japanese bullet train can be moved by rapidly alternating, albeit static, electromagnets.
Also,
This explains everything about the failed Soviet liquid metal cooled-reactor scheme.Quote:
Originally Posted by Wikipedia
set price of unit is 280 euro...rip off
( http://translate.google.fr/translate...-8&sl=fr&tl=en )
$399 usd.
Well, it is technically a double pass radiator. Now we have to see if it is capable of dissipating as much heat as a 120.3 or something..
ROFL ROFL ROFL
at the RRP :rolleyes:
That's the thing - I'm pretty sure it's been incontrovertibly shown that it could not be better, or really even somewhat similar.
What it boils down to: There is only one fan removing heat and has a limited amount of surface area. We've gone into more detail on the ability of the pump elsewhere, but the previous sentence is going to be a huge reason why this couldn't be better than water cooling.
