2B pencil yes
Nice rig there varrius, how about scores in 3dmark with those monsters in SLI :D
santa was good this year
im going to add this to a evga 780i
http://i107.photobucket.com/albums/m...6/DSC09835.jpg
nice cpu
good luck with it :) but I will wait for the Q since QX is to expensive
I thought the 9550 was going to have a 8.5 multi? That's bad enough but 7 would really blow. :(
i got it to pass prime blend for over 4 hours, requires alot of voltage from the NB, 1.5+ to pass, all other voltages are either on the highest green, or the on first red.........so if ur running 4gb at high frequency you are going to need alot of voltage to pass.
well the mod seemed to work out, what is a good software program that works on this board to monitor volts?
putting 780i on triple 8800 gtx (water) with QX9650 on modifed Vapochill tomorrow guys . . .hope for good benches . . .
Very nice, look forward to your results.........
a good program to monitor temps is http://www.cpuid.com/hwmonitor.php :up:
Well... running @ 3.4Ghz 425 FSB, memory manually set at the ram's rated speed of 1066.
I wanna point out something in the Guru3D Review
Since when did Intel have Hyper Transport :rofl:Quote:
To fine-tune for stability you can change out the HTT Link Multipliers (1x to 5x), both for upstream and down stream, so that you do not push the Hyper Transport speed way out of stability while adjusting the base reference clocks.
nVidia chipsets use HTT to talk to the cpu, by lowering the multi to 4 and taking the HTT mhz to 300 you have a HTT of 1200, 300x4, stock is 200x5.......i have tested this and a bit of performance is gained by doing this....if you are benchmarking, every bit of extra is usefull.
The Areca ARC-1210 8X pci-e Raid card works just fine in the middle slot. Just thought I'd give you all some feedback. I just finished installing the board. No testing done just yet, but will post back when I do.
Shawn
hurry up!!
jk have fun
