Tony, while you're at it, can you check what happens if you change CPU multi to 11.5x or 12x through P-States? :)
If it's anything like on MSI, then it'll just stay at the maximum stock multiplier (11x on 9500).
If I change NB to past 9x multi through P-States, the system will downclock the NB/CPU/HT to keep below 2GHz NB. Like this:
http://img403.imageshack.us/img403/9...wnclocksr2.png
My board has issues with AOD, only 2.10 works with it and still freezes the system up at times, hence why I can't really oc. I have to keep reinstalling it to keep it working well or it bugs out after a while and the shortcut disappears. It does however report everything correctly.
EDIT: the support forum in your sig is down. ;)
