8488 3dMark06 using my main rig below. Screeny and link.
http://img456.imageshack.us/img456/7...ekoaka0.th.jpg
Futuremark ORB Link
3DMark Score 8488 3DMarks
SM 2.0 Score 3941 Marks
SM 3.0 Score 3430 Marks
CPU Score 2348 Marks
Futuremark ORB Link
PowerCollor HD 2900XT @ 901/950
http://i30.photobucket.com/albums/c3...ric/Best06.gif
Score 11766
Sm 2.0 5091
Sm 3.0 5781
Cpu Score 2673
ORB: http://service.futuremark.com/compare?3dm06=3673914
Not max yet, did a quick bench at my lunch. Need to go back to work now!
Great results BadNizze!
Well ive been doing a lil bit of tweeking and Drinking and Tweaking and Drinking and a few shots here and a few shots there and now i am happy to say the New( Nvidia Beta 169.04 XPproX64bit driver) gave me a few Hundred points over my OLD SCORE of 11756All i did was change driver and update RivaTuner to 2.6:yepp:
I can crank on my Mhz's some more ,As you can see ive been crunching on my SM2.0 and Sm3.0 scores...So far im not At my Old Oc with this Card due to the Drivers and New Versions of RivaTuner....There is just way more tweaking involved to get back to my Highest Mhz ,for the most part that is my main goal now and maybe to 13's on Air :D ...
I cant believe how good the A3 revision is on these things....For the most part look at my FillRate and Bandwith compared to a GTX Hmmmmmmm only afew points lower !!!!!!!!!!!!!!!!!!
Performance.................................................. .......THESE are the GTX specsBFG-Tech OC
GPU NVIDIA GeForce 8800 GTX
Core Clock 600MHz (vs. 575MHz standard)
Shader Clock 1400MHz (vs. 1350MHz standard)
Fill Rate 38.4 billion/sec.
Stream Processors 128
Memory
Video Memory 768MB
Memory Type GDDR3
Memory Data Rate 1800MHz
Memory Bandwidth 86.4GB/sec.
http://i168.photobucket.com/albums/u...SDriver169.jpgThis Screen says it all and im happy,Oh dont worry im not done yet
P.S. Santa :rofl: Please send me a new AMD 4CORE so i can spank *ntel'$ with my BFG:rofl:Ive been good really:up:
@gOtVoltage are you mad??!! :p:
You making me no other choice than voltmod my HD2900Pro or buy 2x3850... :D
Congrats on your score, it is truly awesome!
PS. How is Crysis playing on your rig??
PS2. If you writing to Santa put some good word about me as well plz!;)
@BadNizzle Awesome clocks on your card!
Just push your CPU a bit further and if possible clock memory higher and you're set for SC record on AIR! (AMD of course)
What is the SC wr? Posted a 1196** Score in the Gigabyte 790Fx Thread. Just a shame i forgott to use lod in CCC.... Hoping fore cold temps tomorrow for 12k action! How is your proīs doing in CF? Tested OC bios for them? http://forums.techpowerup.com/showthread.php?p=516143 Have not tryed my self so I donīt know if they work...
Sorry 4 be the Party pooper :p: but my EVGA 8800GTX KO edition is due today
Who should get SC record here then :rofl:
great OC guys... any1 know a vista calc i.e add 5% performence to that vs XP just i dont have XP but my dad has copy so dont have to register it and got spare IDE hd sooo...
1St ... Psycho Eddie :rofl:
Just did quick run to test card working all @ stock i.e CPU 3Ghz... and i got close to that bar :p:
Will put XP onto IDE hd 2moz and put a new score up
8800GTX is A2 revision core so not expecting godly OC didnt get the Ebuyer one in the end as they canceld my order currently disputing my claim with consumer direct on that matter but still i got one second hand but cost £280 delivered vs £270 brand new for that sweet deal thats now back to £390!!
Whats your best Single card score??
3DMark Score 12234 3DMarks
SM 2.0 Score 5362 Marks
SM 3.0 Score 6801 Marks
CPU Score 2322 Marks
http://service.futuremark.com/compare?3dm06=3473057
__________________
CPU: Amd FX-60 @ 3.185 http://valid.x86-secret.com/show_oc.php?id=258037
GFX: 2-XFX 8800GTS (640) SLI @ 678/1675/1100
RAM: 2Gb Patriot Extreme DDR 400 @ (456 2.5-3-2-5-1T)
MB: Asus A8N SLI Deluxe
HDD:2-Fujitsu 74GB U320 15,000 rpm SCSI 0-Raid, 2-Seagate 320GB 7000.2 0-Raid
PSU: 650W Antec True Power Trio
Screen: 19" Wide screen
Got spare HD out of garage and put XP onto it got latest drivers etc..
Then i went about finding my cards maxish oc
655/1700/2150 (A2 Revision 8800GTX)
then went Bios set CPU 14x250 @ 1.525V and PCIE to 130
And we get...
3DMark Score 12615 3DMarks
SM 2.0 Score 5781 Marks
SM 3.0 Score 6121 Marks
CPU Score 2711 Marks
Quite pleased with EVGA 8800GTX KO card idles @ 55C also card looks great through side pannel will update with nice piccy soon :p:
Good guess btw @lightman
Will update score when i get any new hardware but for now im quite contemp with that score could probs squeeze 100 points more but CBA for much time with little results..
8800GT SLI will be next upgrade when EVGA SSC editions clocks 700/1750/2000 come out in DEC but will buy two months after to let prices go down :)
please use amd overdrive tool to overclock it further http://global.msi.com.tw/index.php?f...6&type=utility
I'm pretty sure you have WR on AMD/AMD :up: , but guys with 8800Ultra are holding WR in general AMD ORB.
If you can get into 12K territory then we will have big :party: :party3: here on XS :p: !
Hope you can make it :up:
WOW! I must start taking money for predicting stuff :p:
Looks like WR on 8800GTX for me :clap:
With similar CPU clock this cards gives you almost 800 points more than my HD2900 @860/990! Very impressive!
Thanks for this linky! I was looking for it! :up:
Hey i finally posted my factory GTS Mods ,let me know what ya think . im also shooting for 13000+ on Air with my X2:up:
http://www.xtremesystems.org/forums/...d.php?t=165989
Hows this so far? just so people know ive kept my CPU @3.48mhz since my first post of 10600 points .I have been only working on SM 2.0 and SM 3.0 scores which are the video card. When i can no longer get higher scores from the 8800 ,I may have to Volt Mod it ...
If all else fails then and only then will i raise my CPU above 3.5Ghz...plus i need to get a new pump to do that ..I only have a flow rate of 145gph. Since i had sold my 665 to my brother and he gave me his old MCp355 , I know i will need a another new pump to get 300gph . Thats what it took for me too reach 3.6ghz@1.61vcore with this 6000+ ..
So far so good Look @ my memory Oc and my bandwith...Yes i am really @704mhz/cpu @1782/shader @2308mhz/memory with no Voltmods yet. GPU-Z registers the Shader at the wrong speed, It is @1782mhz! When i lower the shader to 1674mhz in Rivatuner i lose almost 300 points on my 3Ddmark 06 score. If i raise it to 1836mhz which is the next level up i dont have enuff juice! Even if i lower my memory it will fail Test #2, so i guess my shader is maxed @1782mhz stable after running 3Dmark looped.
http://i168.photobucket.com/albums/u...1782s1154m.jpg
Hi,
here a result with my 24/7 settings on Vista 64Bit. :)
http://www.abload.de/img/06y8hi.jpg
Hey Flix is that on water nice card temp!:up:wqish my Nvidia ran as cool as your ATI
Great results guys!
I'm really amazed by GTX scores! So high with only single card :clap: .
To counter that and secure my record I'm going to push a bar a little higher :D !
I've received 2xSapphire 3870 cards and so far I quickly tried them at 840/2400. Result: 13992 points (CPU 3500, mem unoptimized 1000MHz).
I'm gonna push them to BIOS limited 860 and find memory max on both cards + cold weather for my CPU should be good.
Will post some SS later today....
Little update
http://photos.fotki.lv/photos/13/W00...23_SpainiS.jpg
3Dmark06 - 11048
SM2.0 - 5139
SM3.0 - 5022
CPU - 2544
Nice scores guys!!
@Lightman... score seems slight low for these cards? faster clocks then you had on CF with 2900Pro/XT!!
Expect new driver and mem sorted out would be good!!
Btw! Getting Evga 8800Ultra Beastie in next week or so and selling current gona aim for highest Single card score! over 13K for sure :cool:
:D :D :D :D :D :D :D :D :D :D :D :D :D :D
http://www.xtremesystems.org/forums/...d.php?t=166190
729mhz//1836mhz//2304mhz
:up: On Air with Stock heatsink:up:
I love my GTS320:shocked:I know im Extremly Happy:toast2: :party: :party3: :party: :toast2:
CONGRATULATIONS!!
Impressive GTS no question about that! :up:
I'm also very happy with my pair of HD3870 and rig as a whole!
I've been quiet couple of days because of problems with my PSU....
But thanks to my friend HPN I've connected 2 PSUs to my RIG and voila!!
Here is what it can do without sweating :p:
http://img139.imageshack.us/img139/263/3d0614164jj3.jpg
New AMD WR!!!!
ORB
Now where are those guys with Phenoms to dethrone me?? Should be easy with Quad ;) !
Wow congratulations Lightman !!!
Now get Phenom inside your rig and launch an preemptive attack on ORB :p: (in case somebody gets a Phenom with CF 3870 and tries to dethrone you :D)
