:ROTF:
Kent Bench. Look at all the diff bench results.. same speed, same enviroment.
Phelan... is that the Kent rig in sig at 3.2? Man you need to look at the one above for me and look for ~5500 for drys.
Wow, those benches are waaaay off.. Ok do this, stop all work and network access- reboot- open boinc and run 3x... If this persists then send the cpu to me:D No, really if its still low keep running the benches but give it at least 1 min between your rebenches.
For a couple days I noticed every time I ran my benchmarks it was low like
3200
3400
I was giving it a day in between benchmarks cuz they got lower each time I rebenched. So I just ran today at 390x9 3510mhz
3298 floating point MIPS (Whetstone) per CPU
6898 integer MIPS (Dhrystone) per CPU
So these went up since the last time I benched.
5/11/2007 12:22:01 PM||Suspending computation - running CPU benchmarks
5/11/2007 12:23:02 PM||Benchmark results:
5/11/2007 12:23:02 PM|| Number of CPUs: 2
5/11/2007 12:23:02 PM|| 2490 floating point MIPS (Whetstone) per CPU
5/11/2007 12:23:02 PM|| 4581 integer MIPS (Dhrystone) per CPU
5/11/2007 12:23:03 PM||Resuming computation
oh, and, hello everyone.
My C2D Celly 1Mb SC gets 3100/6666 at 3530Mhz.
@Milly, :welcome: If you need anything or have any questions please dont hesitate to ask.
Oh I didnt see Millys' post.
Welcome to the fun :toast: :toast:
e6600 @ 390x9
5/12/2007 11:28:43 AM||Running CPU benchmarks
5/12/2007 11:28:44 AM||Suspending computation - running CPU benchmarks
5/12/2007 11:29:44 AM||Benchmark results:
5/12/2007 11:29:44 AM|| Number of CPUs: 2
5/12/2007 11:29:44 AM|| 3286 floating point MIPS (Whetstone) per CPU
5/12/2007 11:29:44 AM|| 6846 integer MIPS (Dhrystone) per CPU
5/12/2007 11:29:45 AM||Resuming computation
5/12/2007 11:30:21 AM||Running CPU benchmarks
5/12/2007 11:30:22 AM||Suspending computation - running CPU benchmarks
5/12/2007 11:31:23 AM||Benchmark results:
5/12/2007 11:31:23 AM|| Number of CPUs: 2
5/12/2007 11:31:23 AM|| 3290 floating point MIPS (Whetstone) per CPU
5/12/2007 11:31:23 AM|| 4480 integer MIPS (Dhrystone) per CPU
5/12/2007 11:31:24 AM||Resuming computation
5/12/2007 11:31:44 AM||Running CPU benchmarks
5/12/2007 11:31:45 AM||Suspending computation - running CPU benchmarks
5/12/2007 11:32:46 AM||Benchmark results:
5/12/2007 11:32:46 AM|| Number of CPUs: 2
5/12/2007 11:32:46 AM|| 3286 floating point MIPS (Whetstone) per CPU
5/12/2007 11:32:46 AM|| 4802 integer MIPS (Dhrystone) per CPU
5/12/2007 11:32:47 AM||Resuming computation
Chuck, give it a day and rebench and stick with your first bench if its over 6k.. I saw this same thing with my Q6600 the other day so I waited a day and rebenched it and just stuck with the first one.
Will do.:)
Here's mine
E6400 @ 3600mhz
Ohh srry this is just a random screenshot that i got, so i just posted it.
Here is a full shot, if u think somethings wrong, tell me
http://img254.imageshack.us/img254/4...0756ht2.th.png
Just point me towards the legal procedure that i need to follow for a qualified benchmark :rolleyes:
Ahhh those are the Crunch3r files that allows boinc to use SSE3.. We dont want to use those because they are considered cheating.
It's ok but if your running any project using boinc those files are frowned upon:D
Ran it this morning. Got this.
5/13/2007 7:55:12 AM||Running CPU benchmarks
5/13/2007 7:55:12 AM||Suspending computation - running CPU benchmarks
5/13/2007 7:56:13 AM||Benchmark results:
5/13/2007 7:56:13 AM|| Number of CPUs: 2
5/13/2007 7:56:13 AM|| 3295 floating point MIPS (Whetstone) per CPU
5/13/2007 7:56:13 AM|| 6887 integer MIPS (Dhrystone) per CPU
5/13/2007 7:56:14 AM||Resuming computation
My second e6600 at 385x9.
5/13/2007 8:03:00 AM||Suspending computation - running CPU benchmarks
5/13/2007 8:04:01 AM||Benchmark results:
5/13/2007 8:04:01 AM|| Number of CPUs: 2
5/13/2007 8:04:01 AM|| 2232 floating point MIPS (Whetstone) per CPU
5/13/2007 8:04:01 AM|| 3740 integer MIPS (Dhrystone) per CPU
5/13/2007 8:04:02 AM||Resuming computation
5/13/2007 8:04:28 AM||Running CPU benchmarks
5/13/2007 8:04:28 AM||Suspending computation - running CPU benchmarks
5/13/2007 8:05:29 AM||Benchmark results:
5/13/2007 8:05:29 AM|| Number of CPUs: 2
5/13/2007 8:05:29 AM|| 2233 floating point MIPS (Whetstone) per CPU
5/13/2007 8:05:29 AM|| 3803 integer MIPS (Dhrystone) per CPU
5/13/2007 8:05:30 AM||Resuming computation
5/13/2007 8:05:47 AM||Running CPU benchmarks
5/13/2007 8:05:48 AM||Suspending computation - running CPU benchmarks
5/13/2007 8:06:49 AM||Benchmark results:
5/13/2007 8:06:49 AM|| Number of CPUs: 2
5/13/2007 8:06:49 AM|| 2235 floating point MIPS (Whetstone) per CPU
5/13/2007 8:06:49 AM|| 4239 integer MIPS (Dhrystone) per CPU
5/13/2007 8:06:50 AM||Resuming computation
5/13/2007 8:07:48 AM||Running CPU benchmarks
5/13/2007 8:07:48 AM||Suspending computation - running CPU benchmarks
5/13/2007 8:08:49 AM||Benchmark results:
5/13/2007 8:08:49 AM|| Number of CPUs: 2
5/13/2007 8:08:49 AM|| 2233 floating point MIPS (Whetstone) per CPU
5/13/2007 8:08:49 AM|| 4678 integer MIPS (Dhrystone) per CPU
5/13/2007 8:08:50 AM||Resuming computation
5/14/2007 1:05:49 AM||Benchmark results:
5/14/2007 1:05:49 AM|| Number of CPUs: 2
5/14/2007 1:05:49 AM|| 3391 floating point MIPS (Whetstone) per CPU
5/14/2007 1:05:49 AM|| 6776 integer MIPS (Dhrystone) per CPU
5/14/2007 1:05:50 AM||Resuming computation
E6400 @ 3.6Ghz
Updated:
E6400 @3.7ghz
5/15/2007 10:53:19 PM||Benchmark results:
5/15/2007 10:53:19 PM|| Number of CPUs: 2
5/15/2007 10:53:19 PM|| 3464 floating point MIPS (Whetstone) per CPU
5/15/2007 10:53:19 PM|| 7224 integer MIPS (Dhrystone) per CPU
eidt:
E6400 @ 3.8GHz
5/31/2007 10:02:53 AM||Running CPU benchmarks
5/31/2007 10:02:53 AM||Suspending computation - running CPU benchmarks
5/31/2007 10:03:54 AM||Benchmark results:
5/31/2007 10:03:54 AM|| Number of CPUs: 2
5/31/2007 10:03:54 AM|| 3543 floating point MIPS (Whetstone) per CPU
5/31/2007 10:03:54 AM|| 7375 integer MIPS (Dhrystone) per CPU
