I think you need to either have a fan on the heat pipe or replace the stock heatpipe with something else if you are not using a CPU fan. It looks as if you are using vapochill, so the heat will not escape from the heatpipe.
Not using Vapo at the moment, this is all on air.Quote:
Originally Posted by Yoxxy
CPU heatsink is an Arctic Cooling Freezer 7 Pro.
Originally Posted by Durzel
Sad to hear that, I was going to buy that mobo but the lack of people showing off their results from the retail boards on this and other forums has made me hold off buying.
Im now looking towards the Abit AW9-max.
Yeah, I think I'm gonna go back to a P5W-DH - at least if I can find somewhere in the UK that is selling the latest revision. AW9-Max isnt an option for me because using both PCI-e slots would mean no PCI slots available... its a really really badly designed board, I don't care what its capable of. :(Quote:
Originally Posted by Devious
I'm pretty annoyed at the moment to be honest.. I bought a P5W-DH from Microdirect to replace my existing one expecting it to be 68M0AG because they were out of stock... and it turned up 66M0AG. Paid £18 sending it back Special Delivery within the 7 day period - hopefully Ill get a refund on the shipping.
Got P5W64 which I was sure would be the answer to my prayers and would give me 450+ easily - and I hit the same roadblock as I did with my P5W-DH.
Strangely my CPU was showing a lot higher temperatures in Windows than my P5W-DH (up to 50 degrees C idle), despite the fact nothing has changed hardware wise - and the cooler uses the standard Intel push-pin mechanism so theres no real room for a bad contact.
The RAM runs 500Mhz at a non-1:1 ratio, and my CPU will do 3.6Ghz dual Prime stable at 1.4250v. Do I need to run more than 2.1v through G.Skill PC2-6400 2GB HZ to get over 410FSB 1:1, when I don't have to for the 500Mhz on a different ratio?
I could redo the TIM on the NB and SB, maybe even put my Swiftech on it but as soon as I do that I'm stuck with the board - can't return it as "new". I've already got one P5W-DH that "only" has 1.65v vMCH (thanks Asus) which I'm going to have to sell on.
Really don't know what to do at the moment.
Durzel,
If you haven't already done so, it might be an idea to get dirty with Memset and relax some of the alpha timings (beyond the basic 4 settings eg 4-4-4-12).
Read Delay (tRD) of 7 or over may help
Refresh Mode Select (RMS) 7.8us or 3.9us (this value is more relaxed than than 7.8us or 15.Xus)
Everything from and including tRFC downwards try giving a +1 and see if that helps.
I know you already said that you've had 500Mhz at async and so it would be reasonable to expect the same mem settings to work at a lower Mhz in sync but as they say, stranger things have happened :)
Yes - and all out of stock ...Quote:
Originally Posted by smids
There are many others - and it isn't out of stock, they haven't received stock yet. Gawd, use google.pl typing 'asus p5w64-ws pro' - you'd be surprised what that brings up...Quote:
I already bought all my cpu components except for the mobo, I saw this mobo was going to be released soon, so I hold a bit
Seems like I should get a P5WDG2-WS PRO :(
So far what is known about overclocking on P5W64-WS Pro PRO and P5WDG2-WS PRO?
dont know if this has been posted but a pretty good read non the less> http://www.hothardware.com/viewartic...leid=869&cid=3
If it the same like DG2 WS Pro then Vcore actually overvolted. Try a bit more vcore and probly it will help.Quote:
nice link.. :D thanks..
Originally Posted by daos
More vCore???Quote:
Originally Posted by Dumo
Just to reiterate... on my P5W-DH where vCore undervolts (so 1.3250v in BIOS is about 1.28 from memory) I couldn't Clockgen past 410.
On this P5W64 - same hardware, cooler, etc - 1.3250v in BIOS is 1.38v in PC Probe, and I can't get past 410 reliably.
I really can't see how more vCore is going to help this. :(
I tried following what SimonMaltby did before - setting RAM to manual (4-4-4-12) and then using MemSet to set all the subsettings to SPD, but this didn't help from what I could tell.Quote:
Originally Posted by [timko]
Booting straight into Windows with SPD settings also didn't make any difference.
I tried bumping vDimm to 2.3v to see if that made any difference and I was able to MemSet up to 430 before it locked. Trying 440 caused it to lock up.
does anybody know if this board works with a 7950 gx2?
you have good IHSQuote:
contact and the HSF is taking advantage of that.
You need closer to 1.5 or more to get a good overclock with what you have. Try it, but without your LS, it is going to get hot. The conroe's respond to more vcore faster than anything else as far as overclocking.Quote:
so is this the current "best" conroe board for overclocking out or not
________
Volcano Vaporizers
Look here.Quote:
Originally Posted by billdavis
anyone want to buy my opty and expert mobo LOL
it is time for me to go conroe!!
________
MICHIGAN MEDICAL MARIJUANA DISPENSARIES
You can buy it from:
http://www.excaliberpc.com
for only 335 us$ :slapass: Jeeez
;) Go for latest 0209 BIOS on ASUS page - You'll be able to change the multi then.Quote:
:toast:
Yeah I'm all sorted now. :) Thanks :)
I'm getting a P5W64 WS Pro this week and already downloaded latest drivers and BIOS. Today I looked again for an updated BIOS and saw that ASUS has pulled BIOS 0209 from their website. Does anybody know why?
http://support.asus.com/download/dow...20Professional
:eek: Huh, I'm no fortune teller but awaiting my 64 this week I downloaded the 0209 two days ago to be on the safe side.... - what a luck !!! :p:Quote:
Originally Posted by merlin76
Maybe INTEL want to sell more of the expensive E6800 with the free multi - so it could be ASUS got under pressure from them not to release downwards multi free BIOS versions for cheaper chips......:stick:
Just speculation, but similar things did happen many times in the past .... ;)
I used 0209 bios for awhile. Seemed okay to me. Multipliers up to x20 for X6800.
http://img153.imageshack.us/img153/5462/410745ab8.jpg
http://img180.imageshack.us/img180/3...m405245yz6.jpg
