using the last official one.. performing not so bad, but i have problems running these f*****corsair vengeance with reasonable speed.
I just started OC'ing with thus board and am loving it but how do I get past the CPU voltage error during post? Anyway to bypass this?
just put the setting to ignore in the monitor tab
Thanks!!!!
Well, I'm loving this board. With my UD7 I was only able to get up to 54x with my chip. The same chip I can get to the Windows logo screen @ 59x.:eek: Don't know if my chip woke up or what but I'm not complaining.:D
You can get to the windows loading Logo? Or you can get to the windows logon screen? I can get to the windows loading logo with 59X on all of my last 4 chips but only 2 would boot into windows and get to windows logon screen at 55X and 56X. The rest of the chips would freeze at windows loading logo no matter what voltage or settings but would post all the way up to 59x.
Hi, i just receive this Lady yeasterday, and i'm lovin how this baby can make the diference vs P8P67 maxing BCLK.
P8P67 vanilla max BCLK 105,4Mhz
M4E B3 max BCLK 106Mhz, im not finish yet, still more room to go.
I was trying to get those Corsair Dominator GT with chips MNH-E to run Spi32M @ 1833 and 2133Mhz, but no go.
Start spi32M then sistem completly freeze like on P8P67.
I'm starting to think that the problem is my CPU memory controler.
i am using BIOS 3D01_2 (1905)
Need some advise to get this thing running 2133Mhz ... anyone ?
VRM frequency upped ? which timings and volts did you try for the dimms ?
Hi, thx for trying to help.
Well, i was trying 8-8-8-24-1T 1.65v, vccsa: 1.05v Vccio: 1.15v
CPU @ 4ghz 1.3v just for test Dram clocks.
But didnt touch VRm Frquency.
NF200 voltset help mem an cpu
cpu ? low vcore :)
This settings is ok?
http://www.shrani.si/t/1/Vg/2zv5INMy/img0591.jpg
Is 1.5V for 5.0ghz ok for 24/7?
īMTM
set all speed step to DIS..
just noticed that the max VRM frequency on MIVE-Z is 550MHz only in bios 0403
I need higher VRM speed to get lower vcore & avoid BSOD 124
What voltage should change to 5.0ghz? Here are pictures from the BIOS. I have Maximus IV Extreme-Z.
http://www.shrani.si/t/3V/UO/4JGsYot5/img0592.jpg
http://www.shrani.si/t/37/GS/3sciMeA5/img0593.jpg
http://www.shrani.si/t/20/ZU/U3kKTGL/img0594.jpg
http://www.shrani.si/t/1W/bX/4op8gq87/img0595.jpg
http://www.shrani.si/t/1J/z5/1Qg5xYpA/img0596.jpg
Did anyone get any further with this Vcore offset feature, and running a stable setting?
Set this EXTREME PROFILE on YES?
