set your bios up the way you want to overclock...then in windows, you can tweak it with Uguru...FSB and voltages.
Yep c1e and EIST disabled.Quote:
my guess is the ram....try different kind.
i presume you checked that C1E and EIST is disabled.
Trying a stick of Gskill now. Experienced same problems with Gskill to start with. FSB limited to 290. Obviously tried various dividers and what not.
Now out of the blue, I'm gradually climbing again. Currently at 320x9. Really don't know what the problem is.
Just wondering if I over did it expecting to be able to kick off with 420x9 immediately. Almost like something tripped out.
Hopefully I'm back en route.
RLM
Did you give CMOS a good clearing after flashing?
Question about the latest bios (beta). Maybe it was there before, maye not, but what should I set the HPET timer to, 32bit or 64bit mode? Is there a difference?
Shawn
Yep. Took out the battery, moved the jumper. Made a cuppa, rolled a ciggy and went out and smoked it. Then replaced battery and jumper. About long enough:DQuote:
V.True.Quote:
the other thing is if you do not provide high enough voltages, it ain't going to work-ee
All up and running now though. Geils back in 3-3-3-8. CPU 420x9
Only thing I conclude from this is to take it gently gently after a bios flash.
Not really conclusive but
Super Pi 1M (same processes running in background)
B11 Bios 13.485s
B12 Bios 13.435-50s
Guru once upon a time temperature readings same as everyone else. That's with GO chip.
RLM
Help me... when I start Sandra sisoft... what it means??? Oh my god... sorry for file dimension.
IIRC you need Microsoft MDAC installed, I think version 2.0 or higher
ace-a-rue.... flash boot block again with new bios?
again, can you list the switches you used? :D
(for those that can't remember exactly what page you and i had this discussion before) :)
Anybody have a comment I need to cancel my order before the ABIT ships if its not capable of high FSB's like the P5K Deluxe is...
My P5K Deluxe was hitting 550 FSB....but I heard the ABIT could hit 600 FSB with a good CPU
So does anyone know why they made a BIOS for the Anandtech review? Did AT have some issue with the current BIOSes?
While this isn't earth shattering this is with both EIST and C1E enabled. I had 3.2GHz set in BIOS and used uGuru in Windows to bump up the External Clock, Vcore and Vdimm. That's why Orthos and CoreTemp report 3.2GHz but uGuru, CPU-Z, and MemSet get it right. I also like the User Presets in uGuru, very handy.
here ya-go!:cool: http://www.xtremesystems.org/forums/...&postcount=406
substitute "SN" for "SY"...if you do not want to save the original or current bios.
