3 Attachment(s)
high bclock versus high multi on e965
High bclock versus low bclock for same mhz - This is a progress report.
Still trying to find the lowest vcore that can support prime stable 4ghz. Currently priming at 1.3250 vcore.
Results so far - it looks like lower vcore (and lower temps) can be had by going to high bclock/low multi.
Data follows - (FYI - linpack was telling me I had corrupted my vista install, currently priming with 32 bit xp).
3 Attachment(s)
what is better for oc on e965, high bclock or high multi?
Looks like high bclock is better for oc than high multi.
I can get the same 4ghz prime stable with 0.0875v less vcore by using 191x21 vs. 134x30.
Temps are also reduced from 75 to 66C!
Data follows, (config is in my signature) -
