Originally Posted by
a573573
Ya, you can leave Ref Voltages on Auto if you like for sure. It may or may not be stable, but you can leave them. Don't leave Vtt or MCH on Auto though, you would want to set those manually.
If you Leave Ref voltages at Auto they will always be this amount in ET no matter what you set Vtt to, but the actual voltage used will be the respective .xx% amount of Vtt >>>
CPU Reference Voltage (.63% of Default Vtt/1.20) .76 ET
CPU Reference2 Voltage (.67% of Default Vtt/1.20) .80 ET
MCH Reference Voltage (.63% of Default Vtt/1.20) .76 ET
