Okk I finally got it to where I like, but I want to keep tweaking (it's actually fun).
I've had it at 3.91Ghz (8.5x 460FSB) and now 3.92Ghz (9x 435FSB). Which is better, and how do I change my FSB:DRAM ratio as I was running at 1104mhz to my ram (but that was @ 5-5-5-18 and now I'm at 15)?
Anyways, I've been happy and haven't really moved the voltage and the temps are all around 47C idle and 61C during prime95.
http://img394.imageshack.us/img394/4830/cpu5cf5.jpg
http://img525.imageshack.us/img525/1815/ram5fm4.jpg
SETTINGS:
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9x
FSB Strap to North Bridge: AUTO
FSB Frequency: 435
PCI-E Frequency: 101
DRAM Frequency: 1044 (due to my 5:6 ratio)
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: AUTO
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage: 1.35
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: 2.1
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Disabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU Ratio Setting: Manual
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
IntelŪ Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
